Question about Dell Latitude X300 Notebook
Battery not charging
I have a dell latitiude x300 laptop. Battery does not seems to be charging at all. but it works with A/C power. Its a working condition battery (It works with another same model laptop)
  • therumakna Jun 17, 2009
    Thanks guys. You guys are so quick. Anyway the battery does charge perfectly when it is in the other laptop. As you said I have the same feeling that there must be something wrong with the mother board. Looks like I'm gonna open it up and take a look at it by myself.
  • therumakna Jun 22, 2009
    Guys, got the Lappie working again. Its a bit weird situation though. Coz I had to change the power adapter even though it was working with the other Laptop. Anyways all working fine.
    Tanks for yuor help.
    Ta.
    President:
  • 1,185 Answers
Does the battery accept a charge from the another laptop ?, the only way you will know if this is happening is to run the battery down till it warns the laptop it is failing and them plug it into the other machine
If the battery re-charges then it is fine, if not you need to replace it
If your machine works with the AC but the battery stays flat then you have a fault on the onboard circuit that trickle charges the battery and you need a techie
Posted on Jun 17, 2009
  • Tom
    Tom Jun 17, 2009
    If you are going inside the laptop take some precautions
    Remove the battery and the power cable before taking out any of the Ram or Processors
    Look at the input for the mains supply , the charger circuit will be close by
    It is worth getting a plastic probe to gently press the components in that area to see if it is a dry joint on the base of a resistor, they normally put some quite big ones in there to handle the current.
  • Tom
    Tom Jun 22, 2009
    Final comment
    The old charger may be outputting enough current to run the laptop but cannot handle the combined load.
    Without test equipment to monitor the voltage and amperage you are up a gum tree and your swop out method is the best diagnosis.
    Would appreciate some marks on the transaction
    Ps
    I am still trying to come to terms with the other guys statement re watch batteries and take it to a shop and tell me what they said
    Problem Solver:
  • 6 Answers
I had this experience. O(_)O
YOUR battery maybe meets its deadlines!
It is the same situation as what faced in the past few weeks! My battery has been used for years!
Generally speaking, our laptop battery also has its deadline for 1 year. After using it over the battery for 1 years, it will drop to about 60-70 percents of its capacity.
Why not order another laptop battery replacement for bring more convenience?
Latitude X300 Series www.hunt360.net/inspiron-300m.htm
Posted on Jul 01, 2009
    Problem Solver:
  • 9 Answers
It might be something to do with the inside of the laptop my best bet is to take it in to a repair shop and ask the about the laptop battary may need changing inside like a sma3l watch battery.... ask them about ur problem and tell me what they say
I have a Dell Vostro a860. I have a new dell power adapter, a new battery, and have just had the power jack replaced. I still get a message the states that I'm connected but not charging. Any...
Probably the power charging circuit on the motherboard.
The question is, does the battery actually charge, no matter what the screen says? If it's a Dell charger, a Dell battery, then it should work. Some 3rd party batteries cause this message, but in actuality, the batteries seem to charge for the most part.
Jul 02, 2011 | Dell Vostro A860 Notebook
Which is the best operating system that will work on dell latitiude ls H500ST
hi there,
if the configuration like this
http://www4.shopping.com/xPO-Dell-Dell-Latitude-LS-H500ST#keyFeaturesArea
then prefer to install Windows 2000 Professional.
If it works please leave positive feedback.
Thanks
May 15, 2010 | Dell Latitude LS-H500ST Notebook
Dell latitude d500 wont charge.
If the original batteryand the system works on AC power, then replace the battery.
If the battery has been replaced, then it could be a motherboard charger failure
Jan 25, 2010 | Dell Latitude D500 Notebook
Bought a x300 latitude dell laptop. Powers on with ac power adapter, but batteries will not charge even when left plugged in for 6 hours or more. Could it be a bad motherboard??
It could be a faulty battery or a faulty charging circuit.
Rechargeable batteries have a finite number of charge and recharge cycles. There capacity reduces with age until they reach a stage where they won't charge at all.
Oct 24, 2009 | Office Equipment & Supplies
I have a Dell Studio laptop. Will power on with
This should have a "battery check" button on the battery itself. Remove the battery and press the button. If it reveals that the battery is not fully charged, or you cannot get it to take full charge, perhaps all that you need is a new battery. If the battery is failing the check the system makes on it at boot, it won't.
Jun 14, 2009 | Dell Inspiron 1501 PC Notebook
Dell Latitiude D620 blank screen
if u can see dispaly at first when u power up then press F8 key then u enter in enable vga mode.
If u not see any dispaly then refix ram and battery.
then if still problem arise u have reset bios settigns .
for that u have to check on mother bord in laptop pull cmos cell for 15 minutes from it then it reset .
May 11, 2009 | Dell Latitude D620 Notebook
Lost all USB functionality on my Dell Latitiude x300
Hi Wissam !!
Fresh operating system installation is your last option before this you please try to refresh your BIOS. Hopefully it will solve your problem. If you still have any question let me know please.
Thanks
May 08, 2009 | Dell Latitude X300 Notebook
What signal is sent over the center pin of the adapte pug?
my best bet to say for to go to an electronics store and mach up a new one, because to try and test the one you have now would be more costly than to replace it. biigg53566
Dec 04, 2008 | Dell Latitude X300 Notebook
I don't know how to charge my battery
Its ok. Um just leave the battery plugged into your laptop and the power cord plugged into the laptop as well and the laptop will charge it for you. If it won't, the battery is no good and get a new one but you don't need a external battery charger to charge your laptop battery.
Nov 21, 2008 | Dell Latitude D600 Notebook
Dell Latitiude 1100 Will not boot has poweron issue
I also have a dell inspiron 1100. It seems that it has overheated, and your motherboard or CPU has fried, or died from the heat. What you say sounds like a motherboard failure
There is currently an ongoing lawsuit. Also, take my advice, and instead of trying to fix it, you're better of getting a new computer, as the dell is getting old anways. I spent some extra cash and got myself a vaio.
Aug 15, 2008 | Dell Inspiron 1100 Notebook
Dell Latitude X300 Notebook Logo
528 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
