Question about Konica Minolta magicolor 2400 Laser Printer
Printer won't print until I restart my computer.
I have a Konika Minolta 2400W Printer. When I go to print a page it cues it but will not print the page until after I restart my computer. After restarting the computer, it prints the pages that were previously selected to print. How can I fix this?
  • 1 more comment
  • purple_bug Jun 17, 2009
    My printer did print after this, but I have to do this every time i want to print a page. I don't know much about computers! Any suggestions?
  • purple_bug Jun 26, 2009
    I deleted and reinstalled the software, rebooted and tested, same thing happens. After selecting print, i still have to go to the control panel and restart the spooler in order for it to print.
  • Johan Tromp
    Johan Tromp Dec 03, 2013
    Does not help me.
  • 43 Answers
After you have this problem again. Go to Control panel and look for administrative tools. Click on services and scroll down until you see the print spooler service.. Right click on this and select restart. Let me know if the printer then functions after this.
Posted on Jun 17, 2009
  • reedm79 Jun 17, 2009
    Well that is what I thought.. For some reason your printer software is killing your spooler service.
    If you try to print again does it fail again??
    If so - I would remove the printer and reinstall the software.. Reboot and test.
    Let me know! :)
KONICA MINOLTA 2400W PRINT BLANK PAGES
Verify the drive transmission mechanism to developing unit,the image transfer current terminal and the scanner drive transmission mechanism.
Feb 13, 2013 | Konica Minolta magicolor 2400 Laser...
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
May 25, 2009 | Minolta magicolor 2400W Laser Printer
VERTICAL LINES ON KONIKA 2400
If the line is white (no toner is added in that area) check the laser head glass which is located right below the drum. Remove the drum and you should see it below a narrow strip of glass. Just be sure to be clean, with no dirt, toner or pieces of paper on it.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 22, 2008 | Konica Minolta magicolor 2400 Laser...
Only prints on computer restart!
Have you tried a different port?
This will identify if it is a USB issue, possible USB 1 or 2.
It sounds like an issue with your port and not the printer, do you have access to advanced settings on your computer for USB?
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
3,555 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
