The outside home Bryant air compressor is not starting
    Sergeant:
  • 340 Answers
Breaker tripped out of freon open safety switches bad controls you need services. Tom
Posted on Jun 17, 2009
Buzzing Refrigerant Lines
Have someone check your pressures & temperatures in your refrigeration system. Also check the compressor amps with an analog meter to see if the amps fluctuating. There might be something wrong with the compressor.
Jun 12, 2012 | Bryant Heating & Cooling
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
Ac compressor runs, no blower fan. fan and capacitor ok. bryant
so the outside compressor and fan are working good ? If the fan and capacitor check out good then check that the wire from the thermostat for the fan (usually green and tied to grey on a bryant) has voltage and if it does the control board needs replaced because it contains the fan relay
Aug 19, 2010 | Bryant 462AJC021BA Air Conditioner
I have a Bryant 661CJ030-E. While in cooling mode
Refrigerants are regulated by the EPA. In order to purchase it, you need an EPA License. If you are low on refrigerant, the leak needs to be found and repaired. This requires special tools.
Additionally, with the information given, it could be an electrical problem. Is the outside fan running, is the compressor running? Your best bet is to call a professional.
Jul 21, 2010 | Bryant 463AAC008BA Air Conditioner
Air conditioner is only 2 years old. Outdoor fan is not working. Air is circulating inside house but not cool. Bryant Legacy line Model No. 123R Help - seems too soon for the compressor to go bad. What...
You said the outdoor fan is not running, can you hear the compressor running? If you can hear the compressor running then start by checking the fan capacitor. If you can't hear the compressor, then check the breakers or fuses or disconnect. One of these should be located near the outside unit. If you look at the contactor you can see the contacts. When the unit is off they should not be touching, when it is on then the moveable contacts should be pulled down and touching the stationary contacts. You can get some on at the thermostat while you watch the contactor to see if it moves when they change the thermostat to call for a/c. Let me know what you find and I can give you more advice.
Jul 04, 2010 | Bryant Heating & Cooling
Compressor Noise transfering into home
This can happen if the unit was not evacuated and there are non-condensables in the system. Sometimes a line rubs against a floor joist. The compresor can put out a high freqency hum thru the lines. Change compressor. Make sure they evacuate the system. The pressures can be OK when you take them but when the unit reaches a certain pressure it start the viabration. Does the unit have viabration pads nder unit. It can be fixed. I just listed some things I have run into over the last 45 years of service. Rus
Jun 26, 2009 | Bryant 463AAC008BA Air Conditioner
Heating & Cooling Logo
317 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
