Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan 18" wildthing gas/oil ratio ?
Chainsaw
    Scholar:
  • 81 Answers
All poulan products use 40:1. However 32:1 is ok too as it will give your machine longer life.
Posted on Jun 24, 2009
  • 376 Answers
40:1
Posted on Jun 18, 2009
3 Suggested Answers
dennisgladx
  • 52 Answers
SOURCE: Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Posted on Nov 08, 2008
wadingriver
  • 2099 Answers
SOURCE: poulan 18" wildthing chainsaw wont start
have you tried spraying Starter fluid into the Carb to see if it will at least try to run and verify you have good spark?
Posted on Dec 07, 2012
Have a poulan wild thing and the oil bar compartment has gas in it
I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
Oct 28, 2014 | Poulan 18" Wild Thing Chainsaw
My poulan chainsaw,the cilinder gets oil,so the sparkplug gets wet and it will not start
Probably have a Carb. problem. Take the carb apart and clean. The Needle Valve sounds like it is sticking.
Jan 18, 2013 | Poulan Garden
Poulan 18" wildthing chainsaw wont start
Dec 05, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Sep 19, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Poulan 18in 40 cc WildThing ChainSaw Won't Start.
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Apr 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I don't know correct gas/oil mix for the Poulan PP4218 chainsaw?
The PP4218 Poulan Chainsaw operates on a 40:1 gas.oil ratio.
Please rate this solution on FixYa!
Thanks!
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Compression Poulan chainsaw
you can not set the compression on two cycle motors,the compression new is at about 90 to 95 pounds after six to nine pulls of the recoil
Jan 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Nov 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
368 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
