Question about RCA R10 DIRECTV
Loose channells at times, no siginals
RCA receiver at times lose some channells, no siganls. I checked the signals at the transponders and found that only the odd transponders had a signals. The voltage to the dish is 13.33 DC voltage . I don't know model of RCA receiver
  • 1 more comment
  • slapout47 Jun 17, 2009
    this is a RCA satellite receiver. I will lose signals on some channells. I will go the signal meter and will have signals on all odd transponders, not any on even transponders. I read the voltage that goes to the dish(dish input) from the receiver and reads 13.44 DC voltage. I will read 13.44 voltage if I am on a even or odd transponder....thanks
    I have a RCA satellite receiver, times I lose some channels. I go to the signal meter, and has signels on all odd transponders, nothing on even transponders. I have 13.44 DC voltage leaving the receiver going to the dish. I can go from even to odd and back to even, the voltage stays the same
    first thing I did, signal meter shows high eightes and up. I have a clear site to sky.
    President:
  • 1,197 Answers
0% satellite reception means, normally, there is an actual cut in the cable. If you find such cut, you have to redo this connection again. For this, you need, a pair of cutters, utility knife, a pair of coaxial ends and one f81 connector. The following diagram shows step by step how to put a coaxial connector in a cable.
On the right hand side, you will see a female to female connector. We call it F81 or inline connector. This connector allows you to connect the two coaxial cables. Make sure after you join them to use electrical tape to protect connection. After this, satellite signal should be back to normal. It is highly recommended to use electrical tape to avoids any moist or rust going inside the cable. You can also use shrink tape. If the reception is not recovered, your dish might be loose. In fact, it could also means there is an impaired line of sight (like a tree or branching obstructing the view.) There are cases in which strong winds or animals touching the dish produces intermittent signal reception.
Last and not least, if both of these are fine, then, the only thing left to check is the dish LNB . It could be defective. Thus, you need to replace it. The only way to its functionality is by taking it to your local satellite provider company. Thus, they can test it for you. If you got noone to help, you have to buy one and try it at home.
No Reception: The first thing to check is your cable from the dish to receiver. Make sure all connections and connectors are tied. While checking this out, check to see if there are any cuts in cable. If the everything is fine, the next procedure to follow is to check dish condition. Check and see if the dish is solid. Next step to follow is the LNB or dish head. Sometimes, the LNB might be defective. If none of these things seem to make a difference in your reception, you best bet is to check your receiver. For this, you have to take it to a place where it can be tested. Lots of times, people forget that a receiver, might be bad. So, please take that in consideration too.
Signal Cuts In Out: Most of the times, a loose dish causes the signal to cut out. if that's the case, you need to retune and find more signal. A Satellite finder could be handy in this situation.
If that's not the problem, replacing cable ends might do the trick. If that doesn't work, the next step to change LNB. And subsequently, run a temporarily cable. If after, checking all the above, the receiver still looses signal, then you will know, the receiver is the problem.
The most common reasons in missing channels are cable spices, bad connections and defective lnbs. Lot of people don't realize that: splitters CANNOT be used in between the cable communicating the dish to the receiver. If you do, it will work for a while. Then, it will start dropping channels. If you have a splitter, get a joiner to connect both lines. If no splitters found, then a defective LNB is the most probable cause in losing channels. Its hard to physically check whether an LNB is defective or not. The only way you can verify this is by actually replacing it with another one. But, before you do that, you should check if this LNB has an extra port in it. If it does, connect to it. Sometimes, a single port can turns out to be defective.
if this does not help, you have to try the other troubleshooting techniques such as checking cable, connectors, signal reception and receiver.
Most of the time, missing channels is due to faulty cable or LNB. If none of these make it work, then your next best in troubleshooting is your tune up dish to get higher signal. For some satellite systems like Star Choice it could be due to the Network Data Status Code in the receiver is wrong. In plain English, this means, your receiver has been programmed wrong from Satellite Company. So, the easiest troubleshooting option you got here is to phone your satellite provider and tell them to send you another Signal Hit with the proper Signal code.
tuner might also have an intermittent problem... a loose, corroded or poorly installed connector possibly. Make sure the center conductor is long enough to reach but not too long and that there are no stray strands of shield braid touching the center condutor.
Also, you need a separate coax feed from the dish to each input on your DVR. You can't use a splitter. If you are using a splitter, then sometimes you might be able to get two channels, and other times you will get the searching for signal error (it depends on the specific mix of channels you are trying to tune to).
if that doesnt help.... u can try the reset options for ur receiver.....
press and hold the POWER button on the front of the receiver for at least five seconds.
if that doesnt help go in for a hard reset.....
To reset the receiver: 1. Unplug the satellite receiver’s power cord from the power outlet. 2. Wait a few seconds, and plug the power cord back into the outlet. 3. Turn on the receiver and wait for it to download program guide information.
by the time u ve reached this place..... and still no solution... call in RCA....
good luck...
if u feel i was of help... kindly rate my service....
Posted on Jun 18, 2009
  • 749 Answers
You need to realign your satellite dish in the correct place.
Posted on Jun 17, 2009
    Brigadier General:
  • 3,917 Answers
Saving Television Channels I'm not understaning the question. are you talking the sterio receiver or tv receiver? if it is the tv, then you would have to do a "scan channels" as some tv call it. other tv's say "add channels" either or. and some will say something along those lines. but if you have a black out it most likely will lose the channels on some tv's. i have 5 tv's and 2 have to be "reprogrammed" after a power out. Another bit on info. The TV will scan and save to memory what it sees. If the TV is turned off by way of a cable box which might actually be causing the power to be cut off, rather than shut off properly, a part called an EPROM that stores data can become corrupted.. Avoid this problem by turning the TV off by it's own power button. IF this is the answer that helps. A cable box has an outlet on the back for the TV, and that outlet can be taught to stay on wheh the box is turned off, avoiding the trouble causing agent. Then simply reprogram the scan memoy again.
Also
To save money on newer TV's most companies have done away with non-volatile memory meaning it needs no power to retain channel memory. It sounds like you are possibly shutting off the AC to the TV which then will loose its memory and have to be reprogrammed at start up again. If this is not the case then there may be a issue with the memory IC itself.
Mains board need replacement, the memory chips are faulty . Thanks for contacting Fixya.
I have a pincushion problem on the screen , what causes this and how can it be fix?
Not sure what a pincushion problem is? If you mean it pixalates and/or seizes up, runs, you may need to re-peak the dish signal by repointing it, reinstall the dish, if trees or something else is partly blocking signal to the dish. Some transponders on the satellites are much weaker than others. Check signal on the transponder you have the most problems, go to install satellite to check signal. Even rain and snow on the dish or in the air can degrade the picture. Another problem can be caused by used old cable tv wire to bring signal in for the dish. Newer receivers require much more bandwidth that requires good quality RG6 cable coax wire. Even roosting birds can cause problems.. Make sure there is no snow on the dish.
Feb 11, 2011 | RCA Televison & Video
I bought a new hd box and have put the settings exactly the same as on my other boxes(which work fine) but when i check the siganl strength through the new box, im getting great reading from the odd...
Recheck your dish direction and elevation you are probaly off just a hair and
hd receivers have to be fine tuned. They also may not get as high a signal
level as standard receivers
Oct 15, 2010 | Directv (DWO2-10024)
Ew100 receiver is getting siganl but no sound is coming through
Maybe the gain in the receiver is down.
You can adjust the outputgain the menu.
Good luck,
Gerard
Nov 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
NOT CORRECTLY IDENTIFY SAT
The HD feed comes in on 61.5 for a majority of stations most often locals come off 119 or 110. The USA hd comes off of 61.5 transponder 19.If you press menu 611 on your dish remote and manuever the highlight to the satellite and go to 61.5 and then change the transponder to 19 you will probably have a poor signal from 0 -39. Typically this can be resolved by having the dish re-peaked but sometimes foilage may be the cause. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network 301 DTV Receiver
While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
Jul 13, 2009 | Yamaha RX-V861 Receiver
No antenna siganl strength
Antenna may not be compatible with DTV signals or not aimed correctly.  Go the www.dtvanswers.com and click on the Antennas tab at the top for more info.
Jun 02, 2009 | RCA Universal Remote Control
We bought a 20" analog/digital tv the analog channels come on fine but we it scans for the digital channels it says no siginal will we be able to watch it when the change takes place even though we can't...
This could be caused by two different issues.
  • Digital signal reception is bad. The digital signal must be locked in, digital signal reception is either on or off (not like analog signal reception where you can receive a low signal and a fuzzy picture). You may need to adjust you antenna direction and height or obstructions around your antenna, reference the web site for your specific location (address) for antenna compass headings. http://www.antennaweb.org/aw/Address.aspx
  • Television is faulty, digital receiver is bad. Your new television has two receivers, an analog receiver and a digital receiver. A simple power surge will knock out your digital receiver. Make sure you have a quality surge suppressor connected to the television power and the antenna is properly grounded. Return the television for a replacement and purchase a quality surge suppressor.
You must add a quality surge suppressor to your digital television! http://ezinearticles.com/?Power-Protection-in-the-Home-Theater---Use-of-Surge-Suppressors-to-Guard-Expensive-Electronic-Gear&id=41318
Good luck.
Jan 03, 2009 | RCA 20F420T 20" TV
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
Nov 24, 2008 | Insignia Digital-to-Analog Converter for...
Shows canceled?
Make sure u have signal on both tuners on the DVR ( check it in your set-up screen). both tuners should have the same siganl strength. Directv's DVRs, if installed correctly, give u the option of recording one channel and watch another, or recording 2 seperate channels( 2 tuners). If you are recording 2 seperate shows and u change the channel one of your recordings will cancel .
Sep 13, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Stops receiving signals
Make sure that your antenna is in a line of sight such as a window. I know Sirius works in an Easterly direction for line of sight but I think XM works in a Westerly direction for line of sight.
The system has a buffer in it so it can take 5-10 minutes to lose the signal if it does. Keep an eye on the meter.
Aug 26, 2008 | Audiovox Xpress Satellite Radio Receiver...
RCA R10 DIRECTV Logo
104 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
