Question about Refrigerators
My subzero 680, the icemaker has low ice production.
  • 72 Answers
How many cubes is it producing per harvest and how many harvests are you getting per day? You should be getting 8 harvests per day with 8 cubes in each harvest giving you 64 cubes in a 24 hour period. Are the ice cubes formed well? What is the temp in the freezer? Let me know this information and I will hopefully be able to give you a solution
Posted on Jun 17, 2009
Icemaker on subzero 650 slow
check for water flow at water valve or replace water valve
Dec 09, 2013 | Sub-Zero 650 / O Bottom Freezer...
Clogged up icemaker on subzero 601F due to the door not being properly shut. Do I need to defrost the whole freezer to unclog or is there any other way?
You can buy a little steamer at the store and use it to defrost small areas. usually it's the fill tube that freezes, and you can hit just it with the handheld steamer. Lots of times however, this model will create a large ice flow below the glass shelf behind the upper basket and icemaker. this is usually caused by a bad drain trough heater. the only way to defrost this is to turn the unit off for 2 days and put towels down inside it and underneath it to catch the water as the ice melts.
Sep 16, 2013 | APW Wyott SubZero Refrigerator Freezer...
How do you get an icemaker in a subzero 650 refrigerator to stop making ice when the bin is full?
There should be a metal bar that flips when it hits the ice at a certain level. It should stop automatically. There is a problem with the sensor.
Oct 08, 2012 | Sub-Zero 650 / O Bottom Freezer...
Subzero 501F icemaker slow in making ice
More thatn likely, being thats an older model, you are low on freom and the temperature isn't cold enough for the icemaker to keep constant production up. You maybe thinking the freezer is fine because stuff is frozen in there but that is why most people don't catch the problem until they lose all their food. The temperature for the icemaker to even come on is 10 degrees F. The sub zero freezer temperature should be around 0. Check your settings and make sure they are turned down but I would get a thermometer and put in the freezer and check to see what it says. If its above 5 degrees F check your condensor coils to make sure they are clean and also see it the condensor fan is running. If dirty, clean the coils and see if the temperature drops, if not call a service company.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 03, 2012 | Frigidaire Refrigerators
Subzero 632 no water in ice maker ,water supply fine to fill valve,how do you ck valve?
you can check continuity of the valve coil or cycle the icemaker. check the fill tube to the icemaker and make sure it's not filled with ice.
May 22, 2010 | Sub-Zero 632 / S
My subzero 550 ice maker is not making ice
My subzero model 550 is not making ice after I shut the water off for a plumbing repair. Now that I turned water back on my icemaker is not working.
Jan 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have a subzero model 532. I turned off my
its quite possible that your fill tube is clogged with a bit a ice
Oct 09, 2009 | Refrigerators
Subzero 500 series ice maker
It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
Oct 18, 2008 | Refrigerators
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
