Question about Konica Minolta DiMAGE G500 Digital Camera
Konica Minolta D G 600 Zoom does not open fully
My friend took the camera to Egypt and perhaps was exposed to dust. Is there any way to clean it without sending to the Minolta company as this costs more than the camera.
  • 3 Answers
Its possible to take the camera apart, but I don't advise it.
Perhaps by continually moving the parts you may be able to dislodge the dust.
Try putting some high pressure air onto it (I don't know how to do this myself), the sort of pressure you'd get from a car tire pump.
Use a fine needle to try and prise it out.
Buy yourself a new one.
Posted on Jan 03, 2008
Opeate fix this code C-2105 in konica minolta bizhup 600
Transfer/separation cleaning motor home sensor error. Most commonly caused by toner building up in sensor. Open front doors, lower center handle, and pull out transport unit. Located in the middle of the units paper path (to the right of the fuser) is the T/S unit. Located the two screws holding the unit in and loosen them, ones at the front the other is at the back. Pick the T/S unit straight up and out of the machine and clean out any toner and paper dust located in underneath. Reinstall unit and reboot machine.
May 08, 2014 | Konica Minolta Developer 02xk Dv710 for...
I have a konica minolta model 2806-301 and i need an instruction manual for it can you help me?
Really, you are talking about Konica Minolta Dimage Z6 6MP Digital Camera with 12x Anti-Shake Zoom:
MPN: 2806-301
Model: 2806-301
Optical Zoom: 12
Digital Zoom: 4
Maximum Aperture: 2.8
Maximum Focal Length: 69.9
Minimum Focal Length: 5.83
Maximum Resolution: 6
Maximum Vertical Resolution: 2112
In this link coudl find your User Guide: Konica Minolta DiMAGE Z6 (down page, enter verification code to download user manual).
Hope helps (for free, remember to rate this answer).
May 16, 2011 | Konica Minolta Cameras
Konica Minolta Dimage E50 suddenly over expose. Indoor at night, the picture looks almost normal. Daytime the wall will be too white. Outdoor the picture is white out.
The shutter cable inside the lens has broken - a common problem with the E50. The cable moves as the lens zoom so it brakes at some point and then camera isn't able to control the shutter - control the amount of light taken. If you look closely at the over exposed pictures, you will notice horizontal lines accross them.
The shutter or whole lens unit has to be changed. It is quite expensive, I believe it's not worth it. You can contact Sony / Konica - Minolta service center.
I work in a Sony / Konica - Minolta service center and have repaired a lot of these.
Hope this helps!
Oct 05, 2009 | Cameras
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Poor focusing konica Minolta Dimage Z6
I have the same problem and the lens won't retract in.
Sep 02, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Konica Minolta Zoom 160c won't turn on--lens stuck out and open
There is some kind of grit or something in the lens gearing mechanism, preventing its movement. Take it to a repair facility, or replace it.
Jul 26, 2017 | Konica Minolta Zoom 160C Date 35mm Point...
Instruction manual Minolta zoom 130c camera After opening this page look under product description. Click on "Product manual" and it will open up the manual for you for free.
Apr 16, 2008 | Konica Minolta Zoom 130C Date 35mm Point...
Can't start the camera
I had a similar problem.
I'd left the camera unused for over a year...then came to use it, installed new fully charged-up NiMh batteries, but no response at all from the camera.
I found a small black plastic clip inside the battery compartment, close to the opening. It ended up being some kind of reset switch. I depressed this for about five seconds, then installed the batteries and the camera came back to life, as it used to.
Hope this helps.
Jan 09, 2008 | Konica Minolta DiMAGE F100 Digital Camera
Konica Minolta X-370 Wont develop
Two possibilities : 1 ) your film was not properly loaded into the pick up spool and hence it was transported or exposed ; what you took to the lab was unexposed film. 2) the shutter is not opening and again no exposure takes place. To check this open back , set to slow speed like 8th of a second, and see if the shutter opens and closes properly. If the shutter does not open then it will have to go in, unfortunately. Cost ? If it is just an adjustment ( as I suspect is the case ) you should not pay more than $ 100.
Nov 01, 2007 | Minolta X-370S 35mm SLR Camera
No focus
Get Sony to repair it; they bought the division from Konica-Minolta.
Sep 10, 2007 | Konica Minolta DiMAGE X60 Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
