Question about Dishwashers
C7 is flashing
On my GE Profile Dishwasher, as it is running, ''C7'' if flashing on the control panel
    President:
  • 1,197 Answers
C7 means ur temperature sensor has gone bad.....
Replace sensor (located inside door, remove door panel to access)
u can get these sensors for affordable prices at any home appliance parts outlet.....
kindly rate my service....
good luck.....
Posted on Jun 17, 2009
My ge profile dishwasher, pdw7800, just keeps running in the wash cycle
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Jan 25, 2013 | GE 24 in. Profile PDW7800 Built-in...
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Ge profile dishwasher runs for hours
HI, this will occur if there is a major control fault in the timer module or, main control board. Depending on you model, you will need to replace the timer or, control board in this case. this will fix this issue
Jul 15, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
GE Monogram
The control module is damaged and, you will need to replace this device asap. the pump will burn out soon if the control module isn't replaced.
The control module will run you about $109.00
Jun 03, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
The panel on my ge profile ss dishwasher is not working...
At first thought, it sounds like the control board has gone bad. Make certain it is properly plugged in. If no luck there, call the repairman.
Feb 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
My GE Profile Dishwasher is not retaining water and leaking from the bottom.
take off the bottom panel get a flash light and try to see where its coming from its probably from the plastic pump.
Jan 11, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
GE Profile dishwasher GSD4930X88WW will not start C3 error code
The wiring diagram for GE dishwashers is usually found under the dishwasher, take the bottom panel off, then look for a envelope about 3"x5" up against the bottom side of the floor of the dishwasher, right under/behind the front edge. If its not there it makes servicing it tougher. C3 code means the drain sensor is not functioning, C7 code means the temperature sensor is not functioning.
As to the voltages used, I would only know that by looking at the wiring diagram (which I do not have).
Jan 14, 2008 | GE GSD3800G - Multiple Color Built-in...
Dishwashers Logo
158 people viewed this question
Top Dishwashers Experts
