Question about Boating
Stater problems I was wondering if someone could tell me the holmes or voltage that the stater put out on a 1996 150 johnson oceanrunner outboard motor she is carburated the stater number is 584881ev6 15.hv-oa
  • corbinfifiel Jun 27, 2009
    I need it for to start my motor i have got no spark on none of my cylinders i bought a new powerpack and that wasnt it.
    Champion:
  • 207 Answers
Do u need this for a charging issue or a firing issue?
Posted on Jun 27, 2009
  • thomas foster
    thomas foster Jun 27, 2009
    thanks for the rating... you might want to check your tigger switch as well i would tell u the resiter volts but u would only leave me a 1 thumbs up i was only asking to help you but some else can now
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What year is my Evenrude 5.1 outboard
provide a model number and perhaps someone can assist you .
May 10, 2016 | OMC Johnson Evenrude 9 1/4" X 9" Stainless...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Evinrude motor problems
The stater gear is thrown up by the quick spinning of the starter motor. It is on "ramps" that move it up. They can get corroded or gummed up. It should have a very light or dry lubricant on them.
Also if the motor is worn it may not accelerate with enough "snap"
If the battery is weak or the connections are corroded, you can get the same result. Hope this helps.
Jul 27, 2014 | Johnson Evinrude Starter-Outboard -92...
Johnson oceanrunner 175
Outboards are finicky about fuel, probably don't like ethanol. Try some high test.
Nov 26, 2013 | Boating
70 hp johnson seahorse ceased
Hey I recommend checking out the boating forums. Someone over there can tell you whats best. You may even be able to find an answer on there with the search.
http://forums.iboats.com/johnson-evinrude-outboards-24/
Mar 09, 2013 | Boating
Have a 1982 johnson 50hp does it have a return spring on stater plate? when I shift it into gear and advance fuel stater will not return to low idle
There is almost always a direct steel bar or rod link joining those two together. They have a nylon snap ball and socket, or a pin and cotter key connection there some place. Early models worked the other way -using the timing plate to move the throttle.
Aug 22, 2012 | Light Outboard Motor Boat Bass Fishing...
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Mercury outboard over charging
Your motor is fine. It needs to put out more than 12 volts or the battery will not charge. Most alternators put out between 13 - 17 volts, so this is well within the range.
May 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
135 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
