Question about Curtis RT700 7 in. Portable Television
Picture is upside down
Since switch to DTV - I only get spanish channels - and the picture is upside down. Will this work with converter box? or only cable? and how do I fix the picture?
  • jcourt601 May 11, 2010
    I didn't reallize that you were charging for your advice. If I told you how I fixed it -
    I would need to charge you -
Magnavox tv converter box some channels have no sound
When you program your HD converter, it searches for all available channels in your area and you may find, as I have, channels you never knew existed. As for the audio problem, some of the found channels may be so weak that all you get is the picture - no sound. You can delete the problem channels but they are likely to pop up again on your next programming run.
Feb 03, 2013 | Insignia Digital-to-Analog Converter for...
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 10, 2009 | Sony Televison & Video
I recently hooked up my dtv box, tuned the antenna and have a great picture. On every channel I have background noise. Sounds like bacon frying, hissing noise. I also set up someone else's tv, very simple....
If there is a volume control on the remote that came with the converter box, use it to make sure the box volume is set to its maximum. Many models allow you to control the volume out from the box to the TV, and the levels are set about halfway. When you turn up the volume on the TV cause it's too low, you can get the kind of audio problem you describe. Make sure you turn the volume down on the TV first before starting with the box.
Feb 18, 2009 | Directv (R10) DTV Receiver / 70-Hours...
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
Curtis RT700 7 in. Portable Television Logo
70 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
