Question about Samsung SyncMaster 204BW LCD Monitor
Problem with syncmaster 204bw
My monitor keeps blanking out.
the power light stays on but i get the stand by screen come up and then it comes back on after like 15 minutes of me pushing the one and off button on the monitor
i have an inspiron 530 with vista, are there drivers available to fix this?
thanks in advance for your help
    Problem Solver:
  • 18 Answers
Hi there.
unfortunately this is not a driver issue. if possible, test this screen on a different PC/Laptop.
it sounds like a problem with the screen itself - meaning you will have to take it to a service centre, or if its under warrantee - take it to the shop you baught it from.
*** NB note: samsun screens normally carry a guarantee of AT LEAST 3 years, and not only 1 Year.
Posted on Jun 17, 2009
Samsung Syncmaster 204bw has a red screen
A red or pink tint to the screen indicates that the back light bulbs are failing and are about to burn out. Its time to look for a new monitor.
Mar 17, 2012 | Samsung SyncMaster 204BW LCD Monitor
I have a samsung syncmaster 204bw and sometimes the monitor flashes black for a couple seconds and then comes back on. it will do it and then wont for awhile.
This is an early warning that the inverter board is failing, "powers the back lights behind the screen" eventually it will go. The board must be replaced or repaired.
Feb 07, 2011 | Samsung SyncMaster 204BW LCD Monitor
Describe your samsung syncmaster 204bw Problem: I turn the monitor on, the power button turns blue, the screen remains dark, the image on my Powerbook G4 appears flashes on the screen before it goes black...
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 08, 2010 | Samsung SyncMaster 204BW LCD Monitor
My monitor plugs in blue power button blinks why ?
There is probably a failure of part of the power supply pcb. If the light blinks and the screen is totally dark, this is the likely cause. The usual culprit is decective capacitors on the pcb. See other posts on this subject here. This failure may be intermittant; in other words, it may not always occur.
Jun 02, 2010 | Samsung SyncMaster 204BW LCD Monitor
Samsung syncmaster 204bw will not turn on
Check the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 31, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. The images show for a few seconds and goes blank...turn monitor off and on...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | Samsung SyncMaster 204BW LCD Monitor
Plugged monitor in computer... getting electricity... blue light flashing... will not come on
More likely to have bad caps in the power supply just like the other failed SAMNSUNG monitors as shown in my pictures, you can see waht to look for inside:
Please post back what you find so it may help other people as well.
Apr 09, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
I have to hit the power button six times before the screen stays on
Look at the power supply for bad caps with bulging top first, probably the same problem as the other SAMSUNG as shown in my album here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you further.
Feb 16, 2010 | Samsung SyncMaster 204BW LCD Monitor
Difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Jun 27, 2009 | Computers & Internet
Open Questions:
Samsung SyncMaster 204BW LCD Monitor Logo
325 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
