Question about HP PSC 2175 All-In-One InkJet Printer
Hp 2175 all in one displays scanner failed mesage
It has done this from tome to time and usually resets, this time recently the eletricity was interupted and it hasn't reset
Performing a partial reset
Follow the steps below to perform a partial reset of the all-in-one:
  1. Unplug the power cord from the all-in-one.
  2. In the table below, locate the button combination for your model.
NOTE:
If your all-in-one model is not listed in the table, your model does not have a partial reset option.
  1. Press and hold the button combination for your all-in-one.
  2. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
  3. (FROM THE TABLE) HP PSC 2170 series --Press and hold Cancel and the Left Arrow while plugging in the power cord.
Posted on Jun 20, 2009
Scanner failure
You should reset the printer
To reset it:
1.Unplug it (remove the cable physically) from wall or from back side of the unit
2.Keep two buttons down at the same time:
a.cancel button (pink one)
b.right arrow
Buttons have to be kept together!
3.Plug the printer again (don't release buttons!)
4.After that light under three large oval buttons should turn on for a second (short blink).
If that doesn't help - repeat it. If second trial fails - reinstall the driver which is located here or go to HP service.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 10, 2011 | HP PSC 2175 All-In-One InkJet Printer
My hp 2175 printer/scanner now shows up as hp 2170 and will not scan
heres wht u can do.. go to www.support.hp.com enter the model no. of ur printer and search for drivers.. on the next page.. choose support and driver and 1) Update drivers for the printer.. 2) download drivers as per OS of ur computer.. Uninstall the printer from the computer.. start installing the printer again.. but do not plug the USB device to the computer till it prompts u to.. once this is done the issue would be resolved..
let me know if this was useful to u regards, guru
May 06, 2010 | HP PSC 2175 All-In-One InkJet Printer
Is there an update to the driver for HP psc 2175 to improve compatability with Vista? Or am I expected to replace the psc. I have had the HP psc (printer - scanner - copier) for 3 or 4 years, and have for...
Unfortunately HP has not issued a separate Vista driver for your printer. They do, however, give some pointers for setting up and using your printer for printing and scanning.
See this page:
PSC 2175 Vista
Sorry that the news couldn't be better.
Thanks fro using Fixya, just the same.
Wayne
Jul 06, 2009 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 2179 all-in-one printer
Using the instructions found here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
I opened the scanner and found that the cold-cathode lamp is failing. Moving the optical assembly away from its home position (to the middle of the scanner) allows the unit to initialize so at least the printer works.
I'll investigate availability of replacement lamps.
BG
Feb 15, 2009 | HP PSC 2175 All-In-One InkJet Printer
Page Counter?
If the printer was reset recently then you will not et the entire or exact page count till day, but you can still run a Print self test report and check for the information:
To Run:
  1. On the front panel of the product, press Menu (or Setup) .
  2. Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK .
  3. Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK .
It will print a self test page and you will find the page count in thie page
Good Luck
Sep 24, 2008 | HP PSC 2175 All-In-One InkJet Printer
My 2175 printer scanner is in spanish My M
turn the printer on
unplug the power cable
press and hold # and 6
connect the power cable back in and keep these buttons on hold till the screen goes off or says semiful reset, if it turns off press the power button to turn it on and follow the screen it ll prompt u to press 11 for english and so on ...
Njoy
May 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
Aligning new cartridge
I had the same problem and did some searching on the HP support site (what a mess...)
I did find there was a new firmware update for the 2175. I tried it, and it worked for me. The note on the update says that there were problems.
Here's the link:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&os=228&product=90809
Apr 02, 2008 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175 all in one SCANNER PROBLEM
This is only a software issue. Reinstall the software or try installing on other system
Mar 19, 2008 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175 scanner problem
Firmware problem with unit or a stuck keyboard. This is commomn on the PSC series which includes full scanner head failure. Unplug unit from computer to see if it will do it with no cominication to PC.
Mar 28, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
448 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
