Question about Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A
My freezer temp.warning light has come on and wont cool anymore.
Frigidaire gallery upright cu. foot unknown
  • Anonymous Mar 29, 2014
    Refrigerator lights wont turn on when door is opened. Bulbs replaced and that didn't fix the problem
Freezer temp light stays on
Posted on Jun 25, 2009
Frigidaire Freezer acting goofy
Make sure everything is clean of debris and I would personally see if you could cool the area around the unit. Maybe use a fan or turn the air down in that room. Humidity and hot temps kill a unit's sealed system.
Jul 24, 2012 | Frigidaire 21 cu. ft. / 595 liter Upright...
Frigidaire 20 cu ft. upright freezer went out a few days ago. Discovered bottom seal was not in place but fixed that. Alarm light stayed on through the night and freezer is not cooling AT ALL although...
Is your compressor kicking on? If not then check the contactor-relay and the capacitor. If that isn't the problem then it is probably your compressor. Which is quite expensive to replace.
Aug 08, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
I have an Upright freezer. I don't know which exact model I have. (I think the 14.1 Cu In Frigidaire) How do I warn the freezer up a liitle bit? Its too cold.
Here is a link that can help. Let me know what you find while you look at the PDF. Is this your refrigerator? Let me Know, Thanks, Sea Breeze.
Temp. control should be on page 4 part number 18 Turn left for warmer or right for colder. If this don't work then the control will need replaced.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jan 31, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
temperature of the food rises to a level unsafe for long-term storage, the buzzer will
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm
without the alarm sounding.
Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch.
If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and
seals properly. If you suspect a technical malfunction, call an authorized servicer
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire Upright not cooling
Not enough information but  if you are refering to the compressor as the black housing below, it seems that the compressor is either seized or burnt out.
Oct 25, 2007 | Frigidaire 11.6 cu. ft. / 328 liter...
Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A Logo
745 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
