Advent HT3251A tv. The power indicator does not light up. Guess the stand-by power supply is bad but have no idea where it is located on the pcb so I can check components. Can't find a schematic.
Hi my tv dosent want to show chanels
Posted on Jun 17, 2009
Picture lools like hour glass
This sounds like an effect called pincushion. Look under your tv options for an option called pincushion and try adjusting that.
Mar 27, 2011 | Recoton Advent Advent HT3251A TV
Advent model HT3251A
What is the circuit designation of the part in question? It should be marked on the board as Rxxx or FBxxx. Post that here. That should allow us to identify what it is at the very least.
Dan
May 29, 2008 | Recoton Advent Advent HT3251A TV
No input picture, just a blue screen
Its usually a good idea when asking for parts, to include a model #. Thanks Julio
Aug 01, 2009 | Recoton Advent Advent HT3251A TV
Model ht2751a no power,clicks and power light cuts on and off
I replaced caps in power supply.set work fine now.when off light stay blue,when on light is anber.
Jun 18, 2009 | Recoton Advent Advent HT3251A TV
Clicking power supply? wont turn on
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 02, 2009 | Philips 32PF9964 32 in. Television
Advent ht3251a wont turn on
working on same model same symtons,pluged sys into a vareact tv came on normal,problem gone.set works ok when plug into ac outlet.can,t say what cause problem,set work ok now without veriact.will air test three days to see if probem returns.will try freez spay on chips.
Feb 20, 2009 | Recoton Advent Advent HT3251A TV
Ready for nat'l digital transition?
If it is an older model (i couldn't find anything on it either), it most likely does NOT have a QAM tuner. Be aware that only the "un-encrypted" cable channels will be free otherwise you will have to buy or rent the digital box from the company to get the rest of the regular digital channels. The un-encrypted channels are like 71.2, 83.7 so you should know if you are getting those or not.
May 23, 2008 | Recoton Advent Advent HT3251A TV
http://www.pwwservicemanuals.com/om/ht27_3251.pdf
there is a user manual that may be helpfull to u.
good luck.
Dec 27, 2007 | Recoton Advent Advent HT3251A TV
Advent HT2751A display no good until after 1-2 hour warmup - maybe
After 3 years, I finally decided to open up the TV and do some troubleshooting. Found out the problem, It was a blown capacitor Location C554 Capacitor value is 2200uF 16V - costs about a dollar to replace yourself and the TV works brand new.
Aug 16, 2007 | Recoton Advent Advent HT3251A TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
