Question about LG WM2277H Stainless Steel Front Load Washer
Where can I purchase locally an inlet valvue assemly part for my LG WM2277H?
  • 1,305 Answers
Look for an appliance parts house in your area by going to google.com enter your city name or local area zip and "appliance parts" and "LG".
Posted on Jun 17, 2009
How do I replace door latch on LGwm2277h
The service manual for the LGwm2277h can be found at this URL.
http://www.manualslib.com/manual/770130/Lg-Wm2277h.html#manual
The actual step that shows how to replace the latch can be found on page 38 here: http://www.manualslib.com/manual/770130/Lg-Wm2277h.html?page=38#manual
Oct 27, 2014 | LG WM-2277HW Front Load Washer
Lg washer model wm2277hs does not add water
If you mean that water does not come into the machine at all then you need to have the water inlet valves checked by a qualified Technician for correct operation.
Poppa
http://www.cdbaby.com/cd/poppamadison
Jan 16, 2012 | LG WM2277H Front Load Washer
I have an eror message of IE on the display and it did not finish the rince and spin cycle.
This is a very common error on this model. This error indicates a water inlet problem.Check a good troubleshooting flowchart :-
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6350
Few details -
- Make sure that the screens of the inlet valve are not clogged
- Check the pressure switch and flow meter
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 21, 2010 | LG WM2277H Front Load Washer
Not completing cycle error IE
IE is a water supply error. turn water off to machine and unscrew your 2 water hoses on back of machine and clean inlet screens with old toothbrush. if they are clean, you probably have a stuck closed water solenoid.
Jul 25, 2010 | LG WM2277H Front Load Washer
What type of washer does the LG WM2277H take for the cold inlet hookup?
The water supply lines for the LG WM2277H are the same as almost all clothes washers sold in the US, which are standard garden hose threads, and use a standard garden hose washer.
Jun 17, 2009 | LG WM2277H Stainless Steel Front Load...
The backup valvue never turns completely off. is this normal
The backup valve should shut off completely. All the pressure should be going to the Polaris for 3 minutes, and then all the pressure to the backup valve for 35 seconds. If water is coming out of the backup valve when it should be off, then needed pressure to the Polaris is being wasted.
If the Polaris is working fine, then no reason to fool with it. If not, you need to fix the backup unit. You can open it up and clean out debris and readjust it. (You'll really need a "strap wrench" from a hardware store to get off the outer ring. I paid $6). You can purchase the the inside mechanism if you can't fix it. You can also purchase an entire backup valve...outer case and inner mechanism. I bought one for $42 off ebay but they sell for $50-60 and my local pool store quoted $100.
Jun 16, 2009 | Polaris 380 In Ground Pool Cleaner
MY WASHER DOES NOT DISPENSE ENOUGH WATER. IT SEEMS LIKE IT WASHER VERY DRY AND MY CLOTHES SMELLS HUMID. PLEASE HELP
may be it has asmall problem
try to clean the inlet water filter only by teeth brush under tap water
thank you
Jun 09, 2009 | LG WM2277H Stainless Steel Front Load...
No water geting into washing machine.
check hot and cold inlet vavle with meter...do you fell them humming,,or vibrating...
Jan 02, 2009 | LG WM-2277HW Front Load Washer
I have a LG washing machine, model WM2277H. Ready to wash clothes, put the machine on but no water is entering the machine. water valve is open, cleaning the filter inside the hot and cold tubing to the...
Kinked inlet hose. Screened hose washer in inlet hose plugged. Frozen water supply pipe(s). No power to washer inlet valve(s). Old inlet hoses with separated layers, blocking water flow under pressure.
Turn off valves, remove from machine end, put in bucket and turn on valves to make sure you have water up to machine. Now work back to find why you are not getting water into machine.
LG WM2277H Stainless Steel Front Load Washer Logo
81 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
