Question about Kenmore Dryers
Kenmore Advantage Automatic dryer (Model# 69831). This unit was working 2 dats ago and now wont start. We have checked the breaker and it has not been fliped. We think that there might be an internal breaker box or heat sensor that has been tripped. What do you think the problom is?
  • 1 more comment
  • iansmithwc Jun 17, 2009
    I'm haveing trouble getting the back panel off. I've remove all the screws but everything is holding steady and not budging. I'm worried that I will bend the metal if I try to force it. Is there some kind of secret to getting the back off?
    "It sound it need a new thermal fuse.
    This is located the on the back of the dryer neat the exhaust vent, you will have to take the panel off to see it, it is white and about 1 1/2 long by 1/4 wide."
    I have tried to get into the dryer by taking off the panel but am finding this extremly difficult. Is there a step by step giude to get into this dryer or a picture or video would be even better.
    Neither of these are showing me how to get the back panel of off the dryer. Also do you agree with Kevin000 that it sound like a thermal fuse issue?
  • 15,935 Answers
I can better help you locate and disassemble your dryer with a FULL model #.
69831 is not a valid kenmore model.
Please use "Continue with this expert" option and reply with the entire model #.
Thanks!!
Posted on Jun 18, 2009
    Sergeant:
  • 326 Answers
Davesrepair.com/pdfmanuals/km27indrymanual.htm
Posted on Jun 17, 2009
  • SABARI ANAND
    SABARI ANAND Jun 17, 2009
    rakerappliancerepair.com/Course_catalog/Samples/Manual Samples/Manual01_sample.pdf
    Genius:
  • 1,847 Answers
Let me know if you need further assistance
Thanks
Kevin
  • Legin Varghese
    Legin Varghese Jun 17, 2009
    These might be small plastic latch if you have remover the screws, don't force else will break the latch.
    K
Dryer wont start
Did you flip the breaker to the dryer and flip it back on
That has worked for me
Apr 04, 2014 | Dryers
A few weeks ago our kenmore dryer would only dry for 10 mins or so at a time, finally after about a week it wouldn't come on at all. Had a repair man tell us it was the timer. We ordered a new timer...
it it tried to turn on when you flip the breaker then the problem could be a loose connection more often than not dryers pull allot of amperage and if the wires are loose it will from an arc similar to welding and melt the wires the unit runs only when the wires make full contact.
1. turn your breaker off 2 remove the area where the connections come into the dryer check there if all is good there go to 3 3 check the plug 4 check the wall connector 5 check connections at the breaker
as always follow safety guidelines when working on high voltage this is 220 volts
Best of Luck
Jun 02, 2011 | Kenmore Dryers
Circut breaker turned off then turned on dryer wont turn back on (kenmore serial #86982800)
i ve seen this in the field alot of times make sure you actually are getting full 220 to unit.. sometimes these dang breakers look like they are on but they fail to send full power back to unit... it is even happened to me in the field i go to turn power off to a customers unit and when i am ready to turn back on the breaker wont fully reset... check it out if it was working prior to the bresker turned off and you didn't operate on the dryer disconnecting or replacing anything this is your problem...
Jan 02, 2011 | Kenmore Dryers
Frigidaire model # FDE336RES2 Wont turn on.
The fuse is located on the rear wall upper right hand corner. To get to it you must bust dat dryer down. HERES HOW
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2009 | Frigidaire FGR341AC Electric Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
My dryer wont heat up when it drying
Your issue is as follows:
"the dryer works but there is no heat to dry the clothes. model no/stock no- 86983100-69831 kenmore ultra fabric care soft heat dryers"
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is invalid. I have provided some common solutions to help guide you in your search.
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
This information is for an electric, generic model dryer only!
My Solution is:
If your dryer doesn't heat, check these:
Temperature Switch; make sure a positive heat selection has been made, if still no heat, then check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house: Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element: Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse: On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring: A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 17, 2008 | Dryers
Dryers Logo
197 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
