Question about Brother IntelliFAX 4100 Laser Fax
Changing a speed dial number
I have misplaced my manual. I have a Brother Intellifax 4100e, how do I change a fax number that has already been programmed in speed dial?
  • 1,959 Answers
Use menu 2.3.2 to access the number you wish to change. Use the cursor (left and right arrows)to go to the number(s) you need to change, When the cursor is under the digit that needs changing, type in the new number. Continue this process until the number reads correctly. Press SET afterward and the new number should now be saved. Hope this answers your question. All the best!
Greg
p.s. Here is a link to the user guide for your machine: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Posted on Jun 17, 2009
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
Nov 18, 2010 | Brother IntelliFax-4100e Fax
IntelliFax-4100e
go into menu, arrow over until you see 2. Fax hit set, then arrow until you see 1. one-touch speed dial, then hit set. touch the one-touch button you want to change, then the number 1 to change it, it will display the number, hit clear to delete it then dial the new number hit set and you're done.
Feb 11, 2010 | Brother IntelliFax-4100e Fax
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 10, 2010 | Brother IntelliFax-4100e Fax
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
Brother Intellifax-4100e changing Pick up roller
Push the arms that limits the lifting up of the feeder outboard to release the freeder.
Feb 05, 2009 | Brother IntelliFax-4100e Fax
Busy Signal
DO YOU HAVE DIAL TONE ON THE PHONE? IF YES, YOU MAY HAVE A BAD PHONE BOARD. MAY NEED THE HELP OF A SERVICE CENTER. BROTHER TECH
Jan 12, 2009 | Brother IntelliFax-4100e Fax
Brother IntelliFAX 4100 Laser Fax Logo
415 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
