Question about Gateway Computers & Internet
As I was powering up my laptop I opened the cd drawer placed a disk in it. Now it won't close. Tried rebooting, hitting the tab and closing, control panel open drawer, nothing seems to work ????
    President:
  • 1,185 Answers
If the door has shut then look at the facia of the dvd panel and there should be a small hole in it
Get a strong paperclip and push it into the hole, that will eject the drawer
If you have jammed it in real tight get someone else to push the paperclip in the hole while you carefully use two blunt knives to lever on the sides of the drawer
Worse case scenario is that you have to take out the two screws on the base of the laptop and remove the drive altogether to gain access
Posted on Jun 17, 2009
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
Cambridge Audio AZUR 840C Transport Jamming when disk is loaded
The above comment is complete and utter nonsence !
Here's what you do . Take the lid off , take off the top of the cd transport marked "CD 1 Low Jitter Compact Disc Transport" held on with 2 screws , rince it under warm water (its made of plastic) and refit . Its a build up of dust . Yoy will have to do this every 2-3 years . P.S Leave on "stand-by" because you will do more damage to the circuit boards by cutting the power continually .
Sep 15, 2012 | Cambridge Audio Azur 840C CD Player
Cd Dvd writer not working
Select CONTROL PANEL
Select SYSTEM
Select DEVICE MANAGER
(This will show you all your computer's hardware and peripherals)
Locate your CD/DVD "DVD/CD-ROM DRIVES"
Not listed?-Defective or no power. (If you can get drawer to open and close by pressing button, you know it has power.)
Listed? right click it, select PROPERTIES
(Yellow triangle indicates error)
First tab GENERAL shows if it is working properly.
Then click on DRIVER tab to see if you just need to update the driver, or roll back to a previous driver.
Hope this helps.
Mar 05, 2010 | Sony VAIO VGN-N130G/W Notebook
NAD C521 CD Player It will not play my CDs. The CD drawer closes normally with CD in place but after a pause, the drawer opens again. There is no 'no disk' warning. The 'no disk' warning does appear...
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
Sep 07, 2009 | NAD C521 CD Player
Drawers wont open or close.
I will assume you are talking about the CD/DVD drive drawer.
Get a large paper clip. unbend it part way and use the straight end to push the drawer out using the little hole located on the front of your drive.
You may have a stuck disk in the drive.
Mar 19, 2009 | Dell Computers & Internet
Computers & Internet Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
