Question about Kodak Office Equipment & Supplies
Error F60 call service 50FFB200 on Kodak 1500d scanner
Receiving the above message as document tray lifts and then releases
  • cheryl_miles Jun 17, 2009
    so how do you clean the optics, and if we need a new lamp can we replace ourself?
Usuall cause of the problem is that the optics are in need of a very good clean. May also need a new lamp if cleaning does not solve the problem
Posted on Jun 17, 2009
Tengo un error 50FFB800 call Service y no se que pasa
Yo tengo el mismo error, alguien sabe que puede ser? Gracias.
Jan 24, 2014 | Kodak Digital Science 1500D Path-Through...
Tray lifts to meet the rollers then drops back down. Error message 'No page was found in the feeder'
Clean the 'black dot' in the centre of the paper tray. There is an optical sensor under that. The tray will lift even without paper, but will go back immediately.
If the scanner stops after 3 pages, check disk space in your computer. If you are scanning in TIFF uncompressed, it takes lot of space. For color and Grey try JPG format, for mono TIFF G4 is the ideal option.
S. Mohan, Chennai, India
Mar 02, 2012 | Canon DR-9080C Path-Through Scanner
Keep getting error message 100-2105 when I try to scan
I had the same problem. The icon disappeared. Then the 100-2105 error message came up.
The solution on the kodak web site worked for me.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From
your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
Sep 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
DI-450 C-143E
This is originally caused by 'stuff' being stacked on top of the document feeder. When the tray tried to raise the originals into position to feed through the scanner, it is held down by the rear paper guide hitting the stack of 'stuff'. Do this often enough and the release mechanism that prevents damage to the gears and motors gets worn or damaged.
Opening and closing the front door of the copier will reset the error message. If the error reoccurs for no apparent reason, then the tray lift mechanism needs to be serviced. This takes about an hour for a tech to perform.
There is one fix the user might be able to apply. There is a metal tab that sticks out the front of the document tray. When the tray is lifted, the tension on this tab is released. This tab is what applies tension to the internal lift gears for the tray lift. If you can 'adjust' this tab to cause more tension to be applied when the tray is dropped back to its normal position, this might be enough to not get any more C-143E's under normal conditions. Caution is called for as the assembly will not survive any rough handling.
Aug 28, 2009 | Office Equipment & Supplies
Have Kodak 1500d. Import with photoshop turns off computer.
I have library of photos with HP. How do I import them to Kodak. It just comes up with Snapfish.
Apr 14, 2009 | Kodak Digital Science 1500D Path-Through...
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
Looking to purchase the Kodak Digital Science 1500D service manual
You can either buy it from kodak Kodak Customer Support: (800) 235-6325
or you can go to this site as well KODAK
and register
pls dont forget to rate solution
May 02, 2008 | Kodak Digital Science 1500D Path-Through...
550 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
