Question about Dell E152FPc 15" TFT LCD Flat Panel Monitor
My monitor goes dim after a few minutes. When you switch it off and on again the dsplay is ok then becomes so dark
  • Dell Master
  • 1,684 Answers
How dim is dim? If the picture is still visible just like half as bright then your have backlight tube problem and unit LCD needs to be replaced, not worth repair price. If the picture goes out almost to a black screen where you can just bairly see a faint image then you hold the screen just right then you have a backlight inverter issue. If the problem is the inverter then you should be able to replace a few parts and get your unit back going. If you think you can open the unit up and maybe solder a few parts then I would open the case and look for bad capacitors on the power supply board. I can send you pictures of what to look for if you are interested. We also have a repair service for those units, most power issues run $15.00 plus shipping. Let me know if you need help opening the unit and checking parts.
Posted on Jun 17, 2009
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
Presario R3000 display went dark can not see Screen goes black after a few minutes of use. You can see a very faint image after a few seconds, but you must do a soft re-start to bring the screen back....
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 01, 2009 | Compaq Presario R3000 Notebook
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Soyo monitor goes dark every few minutes.
take it a part and look for swelled capacitors take out the bad ones and soder new ones in and then its back on
Jan 13, 2009 | Soyo DYLM24D6 LCD Monitor
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
Monitor Compaq Perisio 7540 (screen goes Dark) complicated
THERE MUST BE A PROBLEM WITH THE VIDEO PROCESSING CIRCUIT LOCATED AT A PCB CIRCUIT ATTACHED AT CRT BASE. THERE MUST BE SOME DRY SOLDER OR A FAULTY BASE CONNECTOR WHICH CONNECTS THIS CIRCUIT TO CRT.
YOU CAN ALSO TAKE A TRY JUST AFTER PRESSING THIS CIRCUIT FIRMLY TOWARDS CRT BASE.
MAIL ME UR RESPONSE @ VISHWAS_4U@REDIFFMAIL.COM
Jun 23, 2008 | Computers & Internet
Dell E152FPc 15" TFT LCD Flat Panel Monitor Logo
818 people viewed this question
Alun Cox
