Question about Electrolux Frigidaire Affinity AGQ8700FE Dryer
Holes in clothes
The last few loads of laundry have come out with pin holes in them. It looks like they have been eaten by moths. I know there are no moths in the house. Any suggestions? Do you think I have the cycle too high?
  • 121 Answers
No yo may have a pin or needle type stuck in your dryer and when clothes go around they get stuck on it cheack drum very carefully
it may be a bra wire that jammed in between drum
Posted on Jun 18, 2009
Loads all of a sudden are unbalanced
look at supports and levelers for out of adjustment or damage
Jun 02, 2017 | GE WSLS1100A Top Load Washer
Clothes have a white colored residue after wash and parts of the clothes are bone dry.
Allison, We are sorry to hear about your concerns in regards to your Washer. We would recommend balling up the clothing similar to the size of a soccer ball, and place around the agitator one at a time. We would also recommend stacking it up so it's around the sides and the agitator plate is visible with all of the clothing around it. Do not fill up past the 2nd to last row of holes in the basket to help overloading. The bulky cycle will allow more water to enter the tub, but will not spin on the highest spin setting. Since the washer uses less water than a traditional washer it makes it harder for it to remove excess detergent, and it can redeposit on the clothing. Use no more than 2 tablespoons per load, filling all the way to the top row or holes. Make sure the water heater is at 120°F, the best temperature to mix with cold water in. A lower temperature may not make the water hot enough, and the detergent will not dissolve properly. If you need any further assistance after trying these troubleshooting tips, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 08, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition...
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Holes
I don't know for sure but suspect it's the plastique/rubber ring between the rotating bin and the rest of the machine (door etc). e.g. for a Whirlpool AWO 3631 it's Part "190 0" on this exploded diagram http://pdf.sogedis.fr/WHIRLPOOL%20AWO3631%20859202429600.pdf
I think they design them to go soft after only a year, so you have to replace them or buy a whole new machine.
Apr 27, 2009 | Maytag EPIC MFW9700S Front Load Washer
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF1240AS0-%3d%3di407639&PartID=407639
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
Maytag Neptune 9700 series
IT SOUNDS LIKE THE OUTER BAND TO HOLD ON THE DOOR BOOT/SEAL. WHAT I HAVE SEEN IS THAT AN ARTICLE OF CLOTHES WAS NOT ALL THE WAY INTO THE WASHER AND IT WAS STARTED, PULLING THE DOOR BOOT INTO THE WASHER. THE ONLY OTHER THING I HAVE NOTICED WITH THIS NEW BREED OF SUPER CAPACITY WASHERS IS THAT THEY LIKE BIGGER LOADS TO HELP BALANCE THEMSELVES. IT MAY BE POSSIBLE THAT IT WAS SO SEVERLY OUT OF BALANCE THAT IT PULLED THE BOOT INTO THE TUB AS THE MAYTAGS OF THAT MODEL LINE WERE KNOWN TO NOT BE THE MOST SENSITIVE TO OUT OF BALANCE CONDITIONS. THERE IS A CONTROL BOARD KIT THAT COMES WITH A MOTION SENSOR NOW FOR THEM AS AN UPGRADE.
Jan 27, 2009 | Maytag Neptune MAH9700 Front Load Washer
go to your local appliance store and ask for "Affresh" washer cleaner. works excellent. If hubby need to get into the machine have hime clean out the pump. You probably have **** in there thats also contributing to the problem. good luck
Jan 26, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Tiny Holes in My Cotton Shirts
If you have granite counter tops then they are ausing it - There is either a small chip in an area where you lean across a lot or your edges are too sharp ( usually with a bevel this happens). I had the same problem for 8 years! Recently put masking tape all the around the edges of my counter tops to test this. No new holes. Just paid a guy to come and smooth down the edges all the way around - expensive but the savings in therapy bills will be worth it- I had been driving myself crazy tring to figure it out and slowly eliminated all other suggestions. I read where one women just started wearing an apron and that solved it for her but I spend too much time in the kitchen for that.
Try the tape - it is a cheap (though not attractive) test. I left it on for a month to be sure. Make sure to check bathroom counters, laundry room ,etc.
Ann
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes stink after being washed
run a empty load of just bleach and keep the door seal wiped down plus when your not using it leave the door open
Jan 11, 2008 | Washing Machines
Electrolux Frigidaire Affinity AGQ8700FE Dryer Logo
277 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
