Question about Stoves 1100DFSID Kitchen Range
Electric stove oven does not obtain proper temperature and does not cycle
Typically, when setting my oven, it will beep four times when the correct temperature is reached and a little pot will display on the control panel.  Currently, my stove will beep four times after being on for a minute or so, before the temperature is reached.  It then does not cycle on and off.  Both the bottom and top element still function.  The broiler is working fine although when used, it too will beep four times after being on for a brief period of time.  This does not appear to affect its operation.
  • Anonymous Nov 12, 2008
    I have a some what same problem the electric sensor come on for about 3 minute then the pilot light but goes back out. I have replace the thermostat in the over that suppose to let the oven know it have reach the temperature i have replace the heating sensor that glows. I have read your article about the sensor might be back. So i taken a look at the control panel and found a diagram of the control panel and it states check the ERC sensor but it dos'nt give me a picture of what it look like. I am a little mechanical with thing and i fill i could fix it before buying a new stove. It is a kenmore wall unit made in 92.
This is a very generic question. If it is an old electric range with mechanical controls, the thermostat may not be cycling properly. Most new electric ranges use electronic sensors which send a signal to a board. This signal changes as the temperature changes. Technically, the resistance of the sensor changes with the temperature and that resistance is the input for the circuit board. The circuit board then adjusts the temperature according to the signal it is receiving from the sensor. A good technician should be able to check the resistance in the sensor to see if it is within acceptable range. If the sensor is good, they would be able to troubleshoot the board or other controls.
Posted on Apr 11, 2008
  • 146 Answers
Itsounds like the problem is in the thermo-couple. This is the "sensor" that monitors the heat in the oven and conveys information to the eletronic controller.
Posted on Nov 03, 2007
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat '
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Temperature probe guide won't quit beeping
you have a bad computer board or clock assy. same thing the most common thing that cooks the board is heat and usually from self cleaning the oven,next time send the model number,if this is a slide in stove under the oven door is a drawer,open it and look at the frame,you'll see a tag with model and serial numbers,if that functions by itself you have a bad board.
Feb 07, 2018 | KitchenAid Ovens
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Oct 17, 2008 | Whirlpool Kitchen Ranges
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
Stoves 1100DFSID Kitchen Range Logo
631 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
