Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Pto won't stay ingaged on 1641 tractor 1993 year with briggs eng.
The PTO goes in but the switch goes back to the center position, I replaced the switch and it does the same thing.If I hold the PTO switch in it stays on until I let it go.
  • mowerman610 May 11, 2010
    steel toggle or plastic push / pull switch
  • 155 Answers
The clutch may need adjusting the clearence should be 10 thou you measure with a feeler gauge through the three holes on the side and adjust with the three nuts
Posted on Jul 27, 2009
Craftsman zero turn 26 hp kohler engine new pto electric clutch does not work
Sad to say it may have never been a bad pto clutch but probably safety switch problem. The running tractor wants you in the seat, brake off, levers over your lap and not backing up for the PTO to stay engaged . There is two push button switches on each lever that lay over your lap ,one on the parking brake,one under the seat. All of these switch wires meet at the PTO switch and all have to agree they are in the position they need to be in to allow electricity to come down the wire to the PTO Clutch.
Dec 22, 2016 | Craftsman Garden
HUSQVARNA Z4824 O TURN MOWER - NOCKS WHAN PTO IS INGAGED & STALLS
need throttle adjustment govenor adjustment possiblt new pto clutch you have to take in to shop adjustmets 50.00 pto clutch 200.00
Sep 03, 2014 | Garden
Pto switch shorting out
is the switch burning up or will it just not ingage blades?check seat switch as well it all works togather.most of the time there is a dioed in clutch wiring system that burns and that will short out pto switch.
Aug 21, 2013 | Husqvarna Fast Tractor YTH24K48 48" 24HP...
Blades won't stay ingaged
bad pto clucth overheating shutting off
Apr 07, 2013 | Cub Cadet Lawn Mower Electric PTO Clutch...
Pto light stays on, tractor won't start (4400)
I would check the PTO switch with a meter, some switches uses 3 or 4 wires 1 or 2 is for the light and the other goes to the clutch. Part of the switch could be bad. Check the voltage on the connector before the switch.
Apr 03, 2012 | Garden
What's wrong when PTO won't engage? On my
should go from the switch to the safety switches to the clutch
Apr 01, 2012 | Briggs & Stratton Garden
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
289 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
