Question about Peg Perego Pliko P3 Classico Freestyle Umbrella Stroller
Handle extension button missing
The button used to extend one of the handles is missing. Any idea where I can find a replacement button?
  • 127 Answers
Call perego at 1800-671-1701 they have them.
Posted on Jun 21, 2009
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
The mechanism to release the extendable handle is broken, is this fixable? when I squeeze the grey button under the centre of the handle only one side of the extending arm releases, i can extend the handle...
Good Afternoon
From your description, what has happened is the wire inside the handle has broken. The wire on its own is not available as a seperate spare part item, to replace this you'd need to replace the handlebar.
Please visit www.quinny.com and choose the country you're in, then select "Contact Us" for your details to be sent into the customer service department in your country and they'll be able to assist further.
May 31, 2011 | Quinny Baby Gear
When bumping up stairs handle bar extends, and feels loose (handle bar is very wobbley)
The Bugaboo is not the ideal stroller for bumping up and down stairs, The reason being it's core design. Most stroller handles have two or more mounting points to the frame but most strollers have baby facing forward and facing the big bad world and not Mummy. The Bugaboo is very clever, the handle can be locked ether way and the seat face either way but the handle has only one point where it attaches to the frame and that point has to rotate and lock. To give you an idea of the forces involved a crow bar the length of the Bugaboo handle can pull six inch nails out of hard wood!
Unfortunately Bugaboo have not used the best material solutions in this critical handle lock. They use a plastic disk to move aluminum locking pins and they fail if you bump down to many stairs. This happened to our Bugaboo in New Zealand. I repaired ours and now I help others by making or sourcing the better quality parts to repair them. I use aluminum for the disk and stainless steel for the pins.
If you are lucky another to have a Bugaboo less then two years old and still have proof of purchase documents Bugaboo will replace the frame for you. If it's older you can buy a new frame for around $400 but this will also increase you resale value by around $200 when you sell it. Lastly you can repair it for around $100 a side depending on parts required, Click on my name and you'll find many posts on how to repair both the Handle lock and the Handle extension lever or wing-nut. macnutz_23.jpg
Nov 26, 2010 | Bugaboo Cameleon Jogger
How to replace rear door handle
you will need to take the door card off of the door, peel back the plastic cover thats on the door, you will need to unscrew the actual door latch should be three screws from the outside, dont pull it out completely, but just lower it a little. you will need an extension and a 10mm socket, either use an extension or a screw bit extender to undo that nut then again with the one on the left. the handle should then push out and lift up from the outside of the car, reverse the steps to get it back in.
Jun 22, 2010 | 1998 Toyota Sienna
I need to find a new handle bar for the quinny buzz as the handle bar will no longer extend
Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm) are the UK suppliers of all spare parts for the quinny range and can supply you with a new handle bar. It's likely that the grey button (handle bar extender button) is broken. This pulls up the little studs on the underside of the handlebar allowing you to adjust. Its a fiddly job but can be done.
May 31, 2010 | Quinny Buzz Three Wheel Stroller
Handle extender button broken wire inside sdo cant
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
http://quinnybaby.com/info_replacement_parts.asp
Hopes this helps, DutchTexan
Nov 01, 2009 | Quinny Buzz Jogger
Pliko P3 handle extension has a missing button
You do'nt have to take a handle of for this you just put it on from outside I did the same thing with my perego stroller you just push the part in the place where the old one was.
Sep 01, 2009 | Peg Perego PLIKO P3 Travel System Stroller
1997 dodge ram truck missing jack handle & extension for spare
any salvage yard or if you write me a mesg with your adress i will sell you the one i have wich came out of a 97 Ram
Jun 16, 2009 | 1997 Dodge Ram 1500 Club Cab
Bugaboo Frog Handle Bars Not Locking into place
Try to contact Bugaboo Service 1-800-460-2922 or serviceus@bugaboo.com
Jan 07, 2009 | Bugaboo Frog Stroller
Peg perego pliko 3 handle extender
Sounds like something is broken inside the handle. The button isn't catching. You could do a few things, quick fix, put a rubberband around the shaft just below the handle when it is extended and it will keep it up high. Better fix, contact Perego and get a replacement handle. If it has been doing this since you purchased it, it may be under warranty. If it is past the warranty period, you can either take the stroller to a Perego repair center near you or potentially replace the handle yourself. Perego customer service could direct you better there. You can email them in the US at: service@pegperego.com
Mar 07, 2018 | Peg Perego Pliko P3 Classico Freestyle...
Peg Perego Pliko P3 Classico Freestyle Umbrella Stroller Logo
226 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
