Question about Dell Inspiron 1501 Notebook
Can not detect power source - Dell Inspiron 1501 Notebook
  • rnettleton Jun 17, 2009
    Green light is on the power brick and the laptop. This message appears when I turn on the lap top and it wants to go into safe mode, so I hit the enter key and it starts up normal and works, just can't understand why it does that every time I turn it on.
  • 43 Answers
Your power brick could be defective. Where are you seeing this message?? In windows??
check for lights on the brick - from the cable to the brick to the PC.
Posted on Jun 17, 2009
  • reedm79 Jun 17, 2009
    When you boot up the machine when you see the PC logo (not windows) press F2 this will take you to BIOS. Look around in there for a POWER option - let me know what your options are.
Error code 06
Look for the leakage source:hoses, actuator, priming valve?
Switch or distributor switch control fault: incorrect detection of cams error in distributor position in cylinder descent phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
Jul 08, 2014 | Krups XP7260 Espresso Machine
Kyocera mita 5035 code 6400 c
Zero-crossing signal problem
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Dec 18, 2010 | Kyocera Mita KM-5035 Printer
I do not know how to install my LC61 series Brother pronter to my laptop.
  1. first install the driver of the Brother printer from the CDROM
  2. connect your printer with the USB cable, and plug it to the power source
  3. power on the printer
  4. the system will detect '' a new hardware detected''
  5. click on the message to add your printer
  6. the sytem will ask you <print a test page ?> choose YES
if you need more help, live a comment. if it was helpfull, don't forget the vote thanks
Dec 07, 2010 | Office Equipment & Supplies
AN SC547 ERROR ON MY RICOH AFICIO MP C3000 MACHINE
547 D Zero cross error § The zero cross signal is detected three times even though the heater relay is off when turning on the main power. § The zero cross signal is not detected for 2 seconds even though the heater relay is on after turning on the main power or closing the front door. § The detection error occurs twice or more in the 11 zero cross signal detections. This error is defined when the detected zero cross signal is less than 45. § Defective fusing lamp relay § Defective fusing lamp relay circuit § Unstable power supply 1. Check the power supply source. 2. Replace the PSU
Aug 26, 2010 | Office Equipment & Supplies
Hi, I have a seagate freeagent external disk with 500 Gb capacity, I had long time without to use my diks, then when I tried to use, It doesn't work, the power source is Ok, but my disk it It doesn't...
is the hdd getting detected....??? if it got detected then format it and try to use... if it is not detected then, let me know, i shall assist you further...
May 17, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Igot a deel and its stuck in power save mode
It maybe a power source issue, this is not easy to detect, consult a local expert. You may also want to check your home power infraestructure.
May 13, 2010 | Dell Dimension 3100 PC Desktop
Why the projector is keep searching
Hi
Is the projector directly connected to the computer? The setting on the projector might be set to auto detect source, could be one reason why when you boot your computer up its detecting for a source where it is attach to. You can set that to manual and by the way change the cable since it seems that the device is unable to detect any source.
Hope this helps
Apr 01, 2010 | InFocus In2106 Projector
Not hard drive but cd boot
Hello my friend, regarding on your problem please turn off you computer then unplug all the power cord connected in your computer to the power source then open your computer kindly check the bus or IDE or Sata cable connected to your hard disk and make it sure that th cable is properly plug and then connect the power cord to the power source then turn on the computer then go to the CMOS setting then check if the hard disk is detected to ensure that you hard disk is functioning. Then check also the priority boot up manager of your computer make it sure that your hard disk is assign to boot up. But if the hard disk is not detected then try to find another hard disk then try that hard disk if it is detected in your system. What ever the result of the test kidly seek any technician in computer in your place to have a second opinion and to ensure that your diagnostic finding is correct.
Hope this solution ables you to solve the problem. If you need more assistance please reply to this post.
Thank you
geo_jonas
Jul 17, 2009 | Computers & Internet
Que drive not being detected
Sounds like a power issue. Check your power source (cable, plug, outlet) If possible try another power cable, or using a different outlet. It could also be a power adapter issue.
Jun 14, 2009 | QPS Que! USB 2.0 Drive CD-RW Burner
How to reset the ink level on a HP C5180
You have to purchase new inks. If you have refills, it will not detect the ink levels due to the chip on the ink cartridge. When inks have been refilled, There is no way to reset the chip.
Feb 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
Dell Inspiron 1501 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
