Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Condensation build-up on the bottom seal of Viking freezer door
I have a side by side refrigerator/freezer and I've discovered a large amount of moisture along the bottom door seal of the freezer.  I recently changed the seal thinking that would solve the problem but the problem persists.  Does the seal need to be adjusted or it is the problem beyond the seal?
  • jeff_young Jun 17, 2009
    Thanks for your quick response.  The unit was made 04/2007
I do not have a solution,
rather, I have the same exact problem.
Have you been able to solve this and how?
Thank you.
Posted on Nov 09, 2009
  • 72 Answers
I have seen this before and it goes beyond the seal, if it was the seal, you would see vapor trails around the area where the seal is leaking. You may have a breakdown of foam in the door. How old is it?
Posted on Jun 17, 2009
  • Michael Willsher Jun 17, 2009
    I would have a factory rep look at it. Call Viking (800) 467-2665, they are in Greenwood Mississippi. I am a Viking service provider and would recommend that you push them to cover the issue, it has been an issue in the past and they are aware of it although they may not admit to it. Good luck
Condensation in freezer
Check the ice chute door to insure that it is closed all the way. They sometimes get crushed ice in the door and blocks closing all the way. Check seal around door and the defrost condensate drain opening to insure it is not clogged with ice and sludge
APPLIANCE 911
Sep 22, 2016 | Samsung White Counter Depth Side-By-Side...
GE side by side, circa 1996, can't find model...refer not cooling.....freezer good
WHAT IS WRONG WITH YOUR REFRIGERATOR?
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Aug 11, 2008 | GE GSS22JFMWW Side by Side Refrigerator
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Why is my freezer not cold enough?
Check the freezer door seal is not leaky. Look for signs of moisture condensation along the door. Apply a thin film of Vaseline along door frame. This will make door seal stick better.
Also check there is no ice building up in freezer. This is a self defrosting fridge and built up of ice inside means warmer temperature. Lower the use of ice cubes from the ice maker to reduce load on compressor as this can effect freezer temperature.
Check freezer is not full of too many items causing reduction of air flow and hence reducing cooling effectiveness.
May 01, 2014 | Kenmore Refrigerators
Ice build up in the freezer
Sounds like your door seals are not seating causing moisture to migrate past the seal and condense and freeze. Check to see if this is true will small strips of paper. If you place the strip in the door and pull, you should have some resistance. If you pull and it moves freely, your door seal needs to be realigned or replaced
Jan 13, 2018 | Amana ARB1905C Bottom Freezer Refrigerator
Why is the ice building up on the bottom of my freezer - viking
check door seal at bottom of door. light a match blow it out, stick it next to seal and see if smoke gets sucked in.. even a little is bad.
Aug 18, 2012 | Viking VCBB363L Bottom Freezer...
When closing the refrigerator door, the suction is minimal so the seal is not really strong in the closed door position. Consequently, condensation builds at the interior door jamb and the exterior door...
I FIND THAT ON ALL MY STUFF WINDOW, DOOR AND ANYTHING RUBBER LIKE, IT'S A GOOD IDEA TO GIVE IT A COAT OF ARMOR ALL. EVERY OTHER MONTH OR SO, IT HELPS KEEP THEM HAPPY. THERE IS ONE THING I FOUND THAT IS A LAST RESORT TO SEAL REPLACEMENT ITS CALLED ''MAGIC LUBE'' W/ TWICE THE TEFLON (HARD CORE !), NEVER USE PETROLEUM PRODUCTS (VASELINE) ON THESE GASKETS THEY **** THE OILS OUT OF THE GASKETS. BAD NEWS
YOU CAN USE A SMALL AMOUNT OF CLEAR SILICONE TO SEAL THE SEAMS WHERE THE GASKET MEETS, NND INSPECT THE GASKET FOR CRACKS IN THE BELLOWS.. SOON AS I GET HOME I'M GOING TO DO ALL OF MY GASKETS , THANKS FOR THE REMINDER. FLORIDA IS HARD ON THEM ... VOTE YES IF I WAS OF HELP.. THNX .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Aug 05, 2010 | Viking 36 in Designer Series Freestanding...
VIKING FREEZER FROST BUILD UP
DEPENDING HOW OLD THE UNIT IS YOU MIGHT HAVE A BREAK DOWN IN THE INSALLATION ON THE SIDE WALLS OF THE APPLIANCE.ALSO CHECK THAT THE DOOR SEALS ARE SEALING OK IF ITS A BREAKDOWN WITH THE INSALLATION THAT MIGHT BE A COSTLY REPAIR BUT GET A TECH TO GIVE ADVISE.GOODLUCK.MOHAMED
Sep 15, 2008 | Refrigerators
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
652 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
