Question about Haier Washing Machines
WASHING MACHINE DOOR WONT OPEN
MY 6 MONTH OLD WASHING MACHINE STOPPED ON ITS CYCLE AND THE DOOR WONT OPEN. YOU CANNOT SEE WATER IN THE MACHINE SO IT SHOULD OPEN. HAVE TRIED RUNNING A COUPLE OF DIFFERENT CYCLES BUT IT STILL WONT OPEN AT THE END OF THE CYCLE. HAVE TRIED TURNIG OFF THE POWER AND LEAVING IT A WHILE BUT STILL THE DOOR WONT OPEN.
CANT SEEM TO FIND THE MODEL ON YOUR SITE AS WANTED AN INSTUCTION MANUAL AS WELL AS I HAVE CURRENTLY MISPLACED MINE. BUT IT IS A
MAKE: HAIER AUTOMATIC WASHING MACHINE
MODEL HNS1260TVE
PURCHASED DECEMBER 2008
  • 3,600 Answers
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Posted on Jun 17, 2009
    Problem Solver:
  • 6 Answers
Sorry if this is a dumb question, but is the cycle 100% over? The safety switch won't release until the cycle is stopped. Maybe start it on the last phase of the cycle and let it finish, then leave it alone for a good minute and a half (it stays locked by program for 60-90 sec after finish). Then you should hear the 'click' of the lock disengaging.
And be cautious, as the Haier's will open with water in the tub, unfortunately. Mine pauses at the end of the synthetic cycle before the rinse and I often forget that it's not really done and subsequently get an opportunity to mop the kitchen floor.
Hope that helps!
Posted on May 09, 2010
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Dec 09, 2013 | Washing Machines
Machine fills for about 10secs then stops and cycle begins.
Check the water level indicator not, make sure it is at full load. Also is the load balanced.
Nov 03, 2012 | Hoover AAA160 Front Load Washer
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
"ZWF160070W1 Washing machine. Only 18 monthe old!
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Nov 14, 2010 | Zanussi WJD1257W Front Load Washer
My GE washing machine smells of meldew, I don't see water in it but when I shake the machine i can hear the water sitting at the bottom. How do i drain this water and also how do i get to it?
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jun 05, 2009 | Indesit W 123 Front Load Washer
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My washing machine has a bad smell and wont work
Oct 20, 2008 | Whirlpool AWM5125/1 Front Load Washer
Smell coming from washing machine
Apr 18, 2008 | Hotpoint WMM39 Front Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
807 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
