Question about Polaroid i733LP Digital Camera
Sliding plastic on battery door is broken, where do i send it for repair?
    President:
  • 828 Answers
See come computer technician if they can fix that...
Posted on Jun 17, 2009
Battery door retaining lugs broken,also the plastic lugs on the main body that the battery door needs to latch onto are broken off ,cannot use camera as unable to secure batteries in the camera ,door will...
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Feb 04, 2010 | Kodak EasyShare C340 Digital Camera
I have a CANON camera A610 - since i changed the batteries it is not powering. The batteries are new. Please advise the possible problem
Double check that the new batteries are actually good. Note that so-called "heavy duty" batteries are terrible for use in digital cameras.
Next thing to check is the battery door slide switch. This is a tiny black micro-switch in the the battery compartment. It's activated by a tiny plastic piece on the battery door slide mechanism that may have broken off.
Dec 17, 2009 | Canon Cameras
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve (SCBENDER@AOL.COM).
Nov 15, 2009 | HP Photosmart MZ67 Digital Camera
Power sliding door opens part way
Replace the wire track harness in the lower door opening.
May 29, 2009 | 2005 Dodge Caravan
2006 Dodge Caravan - ONE power door lock stopped working
i have replaced many sliding door lock actuators on these vehicles..dealer part..mostly on passenger side sliding door..also possible you have a broken wire in door track harness..follow wiring from door into what looks like a plastic chain in door track at door opening
Apr 30, 2009 | 2006 Dodge Caravan
Plastic clip holder to hold dishwasher tray is broken
If you are handy, contact an appliance parts store that sells retail. You should find them in the yellow pages. Brand and model number will be needed usually on the inside edge of the door.
If you are unsure, Look in Repair and Service link at Fixya.com for a repair service in your area.
Good Luck,
Dec 05, 2008 | Home
Broken plastic slides power window
If you go to the VW dealer they make a left and right repair kit for the windows. the kit will come with updated new sliders and cable
reference part # 1CM-898-655-A for the left door
Right door part # 1CM-898-656-A
Jul 13, 2008 | 2001 Volkswagen Beetle
Battery door doesn't close tight
Usually part of the plastic battery door breaks off so the sliding latch (when you push the battery door in toward the camera after replacing batteries) can't latch. If this is the problem you can buy a new battery door that will come with a new latch that isn't broken.
Jul 10, 2008 | Cameras
Battery door broken
You're making it harder than it has to be. Simply hold the camera in your left hand, and open the battery door so it is standing up. Look closely at the lower left corner of the batterry door. Notice the notch shape. The door plastic door is locked in place by the mating little "L" shape on the hinged door of your camera. Thats all that keeps it from sliding off when you put in batteries. Simply insert a small screwdriver or knife blade in that slot, twist it counterclockwise to push the battery door lock to the left, and slide the door off with no force at all. It's a snap.
Jan 15, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Broken part on camera
I suspect you won't be able to buy the part. However, you might be able to fashion a suitable piece of plastic and glue it in place using an expoy resin adhesive like araldite. Or use gaffer tape to hold it shut! Samsung may be willing to repair it but it'll probably cost you.
Oct 28, 2007 | Samsung Digimax D53 Digital Camera
Polaroid i733LP Digital Camera Logo
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
