Question about HP Business Notebook 530
I have a hp530 laptop and it wont switch on
The led doesnt light up when i connect the charger nor when i remove the battery i have purchased a new charger (an official 1) and still no luck , nothing has been spilt on it neither has it been dropped this happened very suddenly it worked 100% fine then when i attempted to turn on it came on for like 3 seconds then cut off it did this twice and since then it doesnt do nothing when charger is connected and when the charger is not connected ..
thank you and suggestions would be greatly appreciated.
  • paul_barlow Jun 17, 2009
    thanks for ur suggestion it didnt solve my issue but i will look in to returning the laptop thanks
    Problem Solver:
  • 18 Answers
You can try to remove the battery (turn over the laptop and underneath, you'll see 2 clips that hold the battery in place).
then with battery removed, plug the charger in and try powering the laptop up. (this would work if you have a faulty battery).
If this doesnt work, I would bet you have a hardware problem (either motherboard or RAM, etc). return the laptop to the shop you purchased it from for further support. (hopefully it is still under guarantee?)
Good Luck!
Posted on Jun 17, 2009
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
My laptop charge wont charge my laptop
is there charging indicator light on ....... check battery maybe its dry
May 30, 2011 | ASUS Eee PC 1000, 1000H, 1000HA, 1000HD,...
My ibm thinkpad from the year 2000 wont turn on. i have connected the adapter and put the battery. i press the button to turn it on but the laptop wont turn on
1st thing you need to do is to make sure the adapter is working.
check to see if any LED indicator lights up when you connect the charger.
if none of the indicators light up with the charger plugged in, you may need to consider replacing your charger/adapter.
however if the indicator come on, then it is most probably a problem with your power/on switch (at the least) or a problem with your motherboard (at the most)
Mar 31, 2011 | IBM ThinkPad T21 Notebook
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
Power cord is working, but computer will not come on and battery does not charge. this is on Dell Inspiron 1545 just over 1 year old.
You can simply remove the battery and connect the Power cord. Switch ON the laptop it should be working now.
Try after some time to connect the battery, If still its not working then you need to purchase a new battery.
Sep 27, 2010 | Computers & Internet
My battery charger input
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jul 19, 2010 | Lenovo ThinkPad T61 Notebook
Battery charging issue
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 11, 2009 | Advent Netbook
Old battery not charging plug in charger green light goes out
If the system will not power on, and the LED on the AC adapter goes out when plugged into the system, then the most likely senario is the motherboard has failed. Remove the battery, Wireless card, Drives, RAM and connect the AC adapter see if anything changes. If no change, the MB is most likely bad.
May 01, 2009 | Dell Latitude D505 Notebook
Amilo pro v7010 laptop wont switch on
If so, unplug it from the wall charger, remove the battery and wait 5 minutes. Then plug the unit back in, leaving the battery out. Attempt to power up. You may lose what work you hadn't saved from the previous use, but nothing else.
If that doesn't work, it's possible that
A) power socket isn't completely connected to the motherboard anymore, so
B) battery isn't charging properly, or
C) the wall charger has gone bad.
I'd say you're in hibernation tho.
Good luck
Nov 25, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
HP Business Notebook 530 Logo
209 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
