Question about Rockford Fosgate Punch 301X Car Audio Amplifier
Rockford Fosgate Punch 301X not runing
I have power to the amp, REM terminal is connected to 12V, but led is not on and amp is off too. i didn't notice any burned up areas or power transistors nor visible damage on pcb.
thank you for response
  • dzzini Jun 17, 2009
    i already tried the suggestions you described to no avail.
    i didnt find any fuse in the amp, but i found in this post (http://www.fixya.com/support/t1456329-fo... ), that this amp has no fuse.
    are there any other steps that i can take, to check if some particular part or circuit is damaged?
  • 221 Answers
You should verify some other way (with a multimeter or another amp/device) that your 12V is working at the amp. Then to troubleshoot the Remote wire, take a short lead of scrap wire and run it from the 12V power input of the amp over to the Remote input like a jumper. If the amp still doesn't power up, then look for and check the fuse on the amp. If there's good power at the amp, the remote input has good power, and the amp doesn't turn on, and the fuse isn't blown, then the amp is probably toast. Good luck!
Posted on Jun 17, 2009
  • Sphynkter
    Sphynkter Jun 17, 2009
    If you open the amp up (which it sounds like you have), the two things I would look for are burn marks or discoloration around the power supplies (mosfet most likely) along the edges. They're usually little squares that are directly attached to the heat sink/case of the amp. They're usually in straight lines along the outter edges. I would also look for capacitors that have blown. The most common capacitor type in an amp is the big cylinder/battery type. On the top of them, you'll normally find a small plus sign or cross. If any of these are "popped" open, then the cap is blown. You could also smell the case for a burnt smell, this usually lingers around for quite a while if the case is kept closed.
I need to wire up a rockford fosgate punch hx2 12" subwoofer to a 500 watt single channel amp and i need to know how to wire the dual voice coil properly ??
Wire it in a series. One wire from amp positive to one positive speaker terminal. One wire from amp negative to negative speaker terminal. This should leave one positive and one negative termianl on the sub. Use one additonal wire to connect these two, this wire should not be connected to anything else other than the two remaining terminals. This will allow you to have the music up louder with higher amp settings without having to worry about blowing the speaker as easily.
Jun 24, 2010 | Rockford Fosgate Punch HX2 RFD1212 Car...
What is rem
rem means remote on the amplifier which means your amp will turn on when ur radio turns on the remote wire goes from the back of the stereo usually always a blue wire to the rem on the input to the amp
May 23, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate Spare speaker termal screws
if you have one that you can compare to another, go to home depot with that and match it up. If not, take the amp to home depot and get someone to help you find the right one.
Jan 29, 2010 | Rockford Fosgate Punch P5002 Car Audio...
401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
try hooking the remote wire to a rem wire on the back of stereo. post and let me know results
May 30, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
Rockford Fosgate P450.4
There is no reset button on the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low. If both are above 12v, the amp will require servicing.
Jun 16, 2008 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Rockford fosgate amp 301X- trouble with wiring remote
You may have open shields on the head unit. You need to check continuity between the shield and the case of the head unit. The following page shows you how to do it.
Shield Ground Repair
Feb 20, 2008 | Rockford Fosgate Punch 301X Car Audio...
Absence of sound
If you have another amp in the vehicle, swap the RCAs and speakers to see if you get sound through the other amp.
Generally, if the red light is on and there is no significant DC on the speaker terminals, the amp is in good working order (for the older Rockford amps).
Jan 15, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
In thermal mode
if i understand correctly its possible that the amp shorted out during the bump...check all connections and fuses, if all is fine then the amp needs repaired.....watch out for those bumps next time.
Nov 11, 2007 | Rockford Fosgate Punch P4004 Car Audio...
301x amplifier
Good luck. Rockford Fosgate does not sell or release any service parts/diagrams AT ALL. They want you to buy a new one or send it in to them to be repaired at an exhorbitant price. Also, from my experience, most RF amps are unrepaairable due to their construction design. the outputs are case soldered and cannot be removed individually. Time to upgrade.
Sep 07, 2007 | Rockford Fosgate Punch 301X Car Audio...
Rockford Fosgate Punch 301X Car Audio Amplifier Logo
191 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
