International dialling codes
Im trying to send a fax to Lithuania do you know the dialling code?
is 00370???
  • Anonymous Mar 14, 2014
    001772643309
  • 1,959 Answers
After dialing 011, the 3 digit code for Lithuania is 370. Dialing 011+370+(phone number) should work. Add 2 0's to the370 if a 5 digit couintry code is necessary. Below is a link to help with interational calling. All the best!
Greg
http://www.q7c.com/travel/telephone.htm
Posted on Jun 17, 2009
  • Greg Margossian
    Greg Margossian Jun 20, 2009
    Kindly rate the solution provided if you feel it fixed your problem.
    Thank you very much.
How to you dial the "+" symbol to send a fax
Hello, have a look at this site of international dialling codes
http://www.famouswelsh.com/00_Clerical/00_Help_Files/Articles/Dialing-Codes.php
you've probably got to just type in '00' before the country code. Regards, nicam49
Aug 18, 2011 | Canon PIXMA MX310 All-In-One Printer
Couldn't send fax. no tapi device found
I presume you are trying to send a fax from your pc?
Most modern pc's do not have an internal modem. Check to see if you have one and if so that it configured for the correct type of dialling ie tone or pulse.
May 30, 2011 | Office Equipment & Supplies
HOW TO SEND FAX INTERNATIONALLY
Sending a fax to another county is easy - almost as easy as sending a fax to someone in your own country. The only difference is the phone number that you'll dial.
When sending a fax from one U.S. city to another, you dial a 1, then the area code, then the seven-digit phone number. When sending a fax from the U.S. to another country, you usually dial 011, then the country code, then a city code (which is like an area code), then the phone number. (The phone number isn't necessarily seven digits.) Check out the web site www.HowToCall.info, which will give you the specific country and city codes for the place that you're trying to send a fax to.
Other than figuring out the phone number, faxing internationally is identical to faxing domestically. Fax machines in other countries use the same protocols as ones in the United States, so you should have no difficulty communicating with a foreign fax machine. Older fax machines and noisy overseas phone lines may cause the transmission to take a bit longer than you're used to, but it should get there.
The first time you send a fax to another country, it might be a good idea to listen in as the fax machine dials. On some fax machines, you can press the "Dial" button to hear the dial tone, and dial the number manually. Listen for the ring and fax tone, then press the Start button to send the fax. You might want to do this the first time you send a fax overseas, just to make sure it's working as expected.
Oct 06, 2010 | Office Equipment & Supplies
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
Mar 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
When ever i recieved fax its gives me fax remote error after 15 20 min it prints
Hi. You may be having a problem with the quality of connection. Check telephone cable for any physical defects. Try to plug printer in a different phone jack in the wall. Try to call your phone company to have the line checked, maybe they can do something to increase the quality of signal. Make sure that you already registered the user information like your fax name and your fax number in the fax by going to Fax mode > press Menu > Fax setup > Dialling and Sending > Your Fax Name or Your Fax Number. You can also decrease the transmission speed of your fax by going to Fax mode > press Menu > Fax setup > Dialling and Sending > Max Send Speed > change the speed to 9600 bps > hit check to save settings. Hope this helps.
Mar 14, 2010 | Lexmark X5470 All-In-One InkJet Printer
International Faxing??
you need an international phone service and dialing capability on your phone, the country code for Australia is 61 so you would dial:-
011-61- Y- xxxxxxxx where 011 is international code from USA, 61 is country code Y is area code and xxxxx is fax number.
Just dial the number as sending a local fax
Dec 15, 2009 | HP 1040 Plain Paper Inkjet Fax
I have a Canon MX850. I have tested the line to have dial tone and followed the instructions to setup the unit but cant send faxes. I dont know if i can receive but when sending it keeps keeping like the...
The fax will only work on an analog phone line, most offices these days especially if you have multiple lines, are digital. You may need the phone company to install a modem compatible phone line.
Nov 05, 2009 | Office Equipment & Supplies
I have a HP j6450 unit and I have no problem faxing to numbers outside my area code, however each time I try to fax to a local number I get a communication error.
If you are doing this an the error is appearing then try removing the area code. Alternatively if you are not dialling the local number with an area code try adding the area code to the number. If that fails then try dialling the number with a telephone plugged into the Telco socket of the machine or directly in to the Telco wall socket to see if it responds to a local only number. If you continue to have problems then contact your local Telco supplier to sort out your problem.
Oct 16, 2009 | HP Office Equipment & Supplies
294 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
