Question about Sony VAIO Notebook
Sony Vaio Notebook PCG-661L - CD/DVD Drive Won't Open
It's a great little laptop, but the CD/DVD Drive will no longer open. For awhile I could use a straightened-out paperclip to open it, but now not even that will work. The cost of a replacement drive from Sony is prohibitive so I thought I'd try taking the drive out to see if I might be able to fix it. I'm guessing this is a mechanical problem, not an electrical one. Unfortunately I can't seem to locate a service or repair manual for this model, and since I'm not a computer repair expert I hate to go digging into the guts without a handbook to guide my way. Can someone direct me to such a manual, or describe how best to tackle the dissection of this computer? Thanks!
  • stoneheaded May 11, 2010
    This notebook model Number (PCG-661L) is not found in any Sony service information database. Please give a corrected make and model number of the notebook you are requesting help for. Thank you and have a nice day!
    President:
  • 828 Answers
Lolz, this time you call a technician, i tell you it will be fix to them...
Posted on Jun 17, 2009
Install ram model PCG-661l VAIO user guide pg 32
The Sony PCG-661L takes DDR PC2100 low density 200pin SODIMM memory. You can have up to 512MB in each slot (there are two slots).
The memory is located underneath the keyboard not on the bottom of the laptop. You have to lift the keyboard up carefully with a very small flathead screwdriver. On both sides of the keyboard there are small tabs that you can press on to release the keyboard. One tab is located just to the right of the "backspace" key. The other tab is located just to the left of the "~" key. Just don't lift the keyboard too much as you will break the keyboard<->motherboard connector. You will see the memory on the right side underneath the keyboard.
Oct 02, 2011 | Sony VAIO Notebook
I need to replace my hard drive in my Viao PCG-GR370 laptop. Is it possible to put in a larger than 30 GB drive?
below is a link for a 320 gig hard drive for your model, i hope this helps
http://www.upgradecomputermemory.com/ram.cfm//memory/s/sony-vaio/sony-notebooks-vaio-pcg-series/VAIO-GR-PCG-GR-Series-Notebook/VAIO-PCG-GR370/320GB-Notebook-Hard-Drive-for-the-Sony-VAIO-PCG-GR370.html
Feb 14, 2011 | Sony VAIO GR370 Notebook
I have a Sony Vaio PCG-661L I shut it down and it won't restart
do you get any leds when charger is inserted? if yes, try to remove battery, insert charger and press power on. also, i would recommend you test the output of your charger using a multimeter to rule out the possibility of a faulty charger.
Regards
Jul 23, 2010 | Sony VAIO Notebook
My vaio cd disc drive needs to be replaced
I have vaio DVD/CD writer.
Sony CD/DVD Unit model AW-G540A it was removed from a Sony Notebook laptop Model PCG-9U1M. The Unit was working perfectly until the laptop was dropped and the screen was damaged,
You can find the specification on the net.
Let me know if it’s suitable for your laptop or if you are interested.
Feb 17, 2010 | Sony VAIO PCG-K35 Notebook
I keep getting this message when i power on my VAIO. "Operating system not found" ? Any help pls will be greatly appreciated
Make sure nothing is plugged in / or in the DVD drive like memory stick / DVD / CD etc.
Retry. if still no go,
Start up in safe mode and see if it starts that way.If it boots into BIOS see if drive is listed.
If still no go a failed HDD is indicated.
Jan 14, 2010 | Sony VAIO PCG-K35 Notebook
System recovery #2 doesn't work
ya i think if you call Sony then can ship you out a replacement cd cause it sounds like disk 2 is not working
Jun 01, 2009 | Sony VAIO PCG-V505EC Notebook
Having a problem getting my Sony Vaio PCG-3E2L laptop to auto play my photo DVD slide show. Using Windows Vista Home Premium OS.Also, where can I find a PDF Sony User Manaul for my laptop?
A quick short cut is to open a browser if you use Internet Explorer and select tools menu, then select Internet options. When the box opens then select the advanced tab and scroll down until you see a check box under security and check allow active content from CD to run on my computer.
Also here is the link for your manual: http://esupport.sony.com/US/perl/index.pl
May 16, 2009 | Sony VAIO Notebook
I am trying to read a data DVD on my VAIO Notebook PCG-FXA36.
just pop it into your dvd drive and view it through my computer or right click on your drive and click on explore. repost here if i missunderstood the question..
Regards..
May 09, 2009 | Sony VAIO FXA36 Notebook
Hot do i open a vio laptop to swap out the cd/dvd rom drive
if u post the problem clearly v can help u for sure
Mar 08, 2009 | Sony VAIO PCG-K25 Notebook
Hard drive compaibility
It should wark just fine
Feb 11, 2009 | Sony VAIO Notebook
Sony VAIO Notebook Logo
631 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
