After formatting my system, I have lost the audio output completely, can any one suggest some fixation to the problem, I am using HP B 2800 Pressario Notebook PC
  • 240 Answers
U need to install sound driver after every formatting of the system. u can download the drivers at www.drivershq.com/Drivers/Devices/HP-ADI-SoundMAX-Integrated-Digital-HD-Audio-Driver/10351/67/Drivers.aspx
Posted on Jun 17, 2009
    President:
  • 828 Answers
Here is the link, dowload your audio software: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1144707&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%C2%BB
My old compa lptop pressario 2800 will not reboot it crashes and then reboots and will not complete the task
Corrupt Windows driver. Possibly because of a virus. Re install Windows as an upgrade from the CD/DVD drive.
Nov 16, 2012 | Compaq Presario 2800 series Laptop...
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Audio driver installation software
Enter your model number here.. (remove the space in the url)
http://welcome.hp.c om/country/uk/en/welcome.html#Support
Jan 25, 2009 | HP 530 Notebook PC
I want audio output drivers
First of all, let me tell you that the DV1000 series Notebooks are divided into two types..
One type is shipped with Conexant AC-Link Audio card and the other models are shipped with Conexant High Definition Audio card.
So, if your Notebook is shipped with AC-Link audio card, you will not be able to install the High Definit audio drivers and vice versa.
So, first, try downloading and installing the Conexant AC-Link Audio card Drivers for your Notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32272.exe
Save the file on the Desktop or My Documents folder and double click once the download is completed to installs the drivers.
However, if you are unable to install the above Drivers, we can come to a conclusion that the Notebook is installed with High Definition Audio and to install this drivers, we need to install the Microsoft Universal Audio Architecture(UAA) drivers before installing the Audio Drivers.
Download the Microsoft UAA Drivers for your Notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Once the download and installation is completed, restart the Notebook and now, you can download and install the Conexant High Definition Audio drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32864.exe
Restart the Notebook and you should be able to use the notebook normally.
Hope this helps...
Sep 02, 2008 | HP Pavilion dv1000 Notebook
Motherborad drivers
Please fly to
http://welcome.hp.com/country/us/en/support.html
And enter your model number for Compaq desktops / laptops and you will be redirected to Drivers download zone.
Please download all the drivers and burn them on to the CD/DVD for future use
Jun 02, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
170 people viewed this question
Alun Cox
David Payne
David Payne
