Question about Canon CanoScan 4400f MultiFunction Color Printer
Green strip across scanned film
How do you get reed og green strip across scanned film?
I have a similar problem using the Canon Drivers - after a month or two of using the official drivers I became unable to use some of the more advanced options - they where still there but wouldn't work properly.
I eventually started using a software called VueScan (Google For It) - and this solved all of my problems, although it is a little more complicated to use, it is a far superior scanning software.
Also make sure you re not trying to save in a color depth that the file format does not support - Eg : Scanning in 48Bit color and saving to a Jpeg
Posted on Sep 24, 2009
My Samsung S7 Edge has a green bar, for lack of a better description comma that goes across the screen and it gets bigger and I can't see my screen at all
Settings > Display > Screen Mode > Adaptive Display or AMOLED Cinema
Also try adjusting your phones brightness to 100% and turn off the auto brightness adjustment to test it out
May 24, 2017 | Samsung Cell Phones
Inability to copy film to pictures
When you were scanning, did you set the scan selection to scan negatives ?
Jan 20, 2008 | Canon CanoScan 8600F Flatbed Scanner
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Distorted colors. Have changed and checked
You've got to clean a Timing **** strip film and a Timing **** disk film.
Jun 15, 2010 | Canon Pixma MP480 All-In-One InkJet...
What is error 5100?
1. clean slit strip film
2. clean slit strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
OR
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Nov 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Scanning 110 negative film
I just finished scanning many 110 film strips. You need to lay the strip along the inside edge of slot A and scan in normal preview mode. On the preview strip, put a marquee around each individual photo and scan each one separately. Worked fine for me.
Sep 27, 2009 | Epson Perfection 3490 PHOTO Flatbed...
ERROR MESSAGE SAYING CHECK 5100
Check your cartridges are good, must be sat correctly.
check that the timing strip is in the center
1. clean **** strip film
2. clean **** strip film sensor
It is located at the back of head carriage, use a contact cleaner.
check something is not blocking the carriage.( usual suspect )
To reset
1. Turn off printer
Or, press reset( or resume) button 4 times then power.
Hope this helps
Regards
Richard.
Apr 21, 2009 | Canon Office Equipment & Supplies
Stripline on my scanned images from Minolta 5400 II film scanner
If some particles of dust stick to the scanning module, then while scanning they appear like lines. Clean the scan module thoroughly using Isopropyl alcohol IPA-Industrial grade is enough, dont use any solvent. You can use your aftershave (!) once or twice. Ensure that the film strips are not sticky.
S. Mohan, Chennai, India
Nov 21, 2008 | Office Equipment & Supplies
Paper not loading, sericr eror message 5100
Dear kamal,
Error code 5100 also come with LED alarm flashes in Orange/Green 2 times. This error happens when carriage part (carriage unit) is faulty so that carriage part cannot read film encoder properly. As a result, carriage part move on uncontrolled. But,in some cases, dirty film timing **** strip (Horizontal film encoder;available only in i series and above) may cause the same symptom. Try to clean film encoder by wiping it with moistened clothe first.
Remedial action:
  • Replace carriage part
  • Clean/replace film timing **** strip
Oct 31, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Officejet 7130 problem with scan
Try cleaning the white calibration strip under the scanning glass (requires technical knowledge).
Try this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01150111&lc=en&cc=us&dlc=en&product=91466&rule=23549&lang=en
Dec 28, 2007 | HP Officejet 7130 All-In-One InkJet...
Canon CanoScan 4400f MultiFunction Color Printer Logo
91 people viewed this question
old marine
old marine
