Question about Kitchen Ranges
I need to change the door front on a h4890bp2s oven and am not sure how to get the old one off. There are the two Torx headed machine screws that hold the top on through the handle and It looks like there are two screws on the bottom back that need to come off, but it looks way to tight of a space without removing something else first. Is there a sequence or an exploded view of this?
    Scholar:
  • 106 Answers
Hi..
Firstly open door fully and then place the metal clips, part B, which form part of the hinge arm, part A, onto the hook on the under side of the hinge arm, part C. Once you have done this you have then locked the hinges in position but be aware that the hinge springs are now fully loaded.
Now you can remove the door as illustrated in the second picture here. There are two movements here but you must hold the door by the sides. Do not hold the door by the handle because once the door is off the oven you will have the weight of the door on the handle, it will break off and your door will be in a thousand bits on the kitchen floor. I have no problem in supplying you with a new door but you don’t want to part with 100 quid at this stage.
While holding the door at the sides, lift it to 45 deg and then pull it towards you. You should now be able to safely remove the oven door....
to view the picture give me ur mail id i will mail u
thank u
rate me
Posted on Jun 17, 2009
How do i remove front panel on meile washing machine w404 plus to rnew door seal
Hi, It would appear that there is alot of miss leading information written here.
Anyway here goes:
Firstly isolate power, It will be easier to view internal workings if the top panel is removed first (remove the cover clips on the side of the top panel to gain access to retaining torx screws) then slide panel backwards to then lift off.
Next..There is a torx fixing screw just just behind the suds draw which needs removing, remove suds drawer completely (press release mechanism) undo screw and keep safe.
The next job is slightly more tricky, pull of control knob carefully, you will then need to remove the facia panel to access the screws behind (facia panel with machine washing details) for this you'll need to use 2 x small stiff pointed implements a couple of stiff sharp pointed kitchen knives will do.
Now this is the tricky bit, locate the points of the knives on the very top edge of the facia panel, gently and firmly push the panel downwards being very careful that you don't slip as you may damage the panel or cut yourself. The panel will slightly move down as it rests on 2 x wire spring clips, your need to prise the panel towards you as you depress this will then allow the facia panel to be removed. Be careful not to loose the spring clips taking note of there position.
Now that bits out of the way the rest is plain sailing.
Remove the 2 x torx screws behind the facia panel located at each end undo and keep safe, carefully remove this electronic panel it will not completely drop out due to the wire connections that's not a problem as you don't need to remove it completely you just need to access a further 2 x torx screws behind this by moving it to either side carefully.
Once you've removed the plastic housing torx screws you can prise out the plastic surround housing casing carefully.
You will now see 2 x torx screws sitting on top of the main front panel these will need removing with the right hand one being a little awkward to access due to the plastic housing dangling in the way.
Next open the front chrome loading door (use the pull cord located behind the filter access door) remove the 2 x torx screws which hold the door locking mechanism (don't worry the mechanism won't fall down behind the front panel when the screws are removed) keep safe.
Next is to remove the lower kick strip at the bottom if the front panel to access fixings screws. You'll need to gently but firmly tug the plastic panel towards you gripping at each end. Once removed undo the 2 x torx screws on the very outer edge the others will not need to be removed.
Lastly going back to the door opening to remove the bolt underneath the rubber seal using a 10mm spanner undo remove and keep safe. Care at this point will be needed as the front panel will only be held on by the door opening grey rubber seal.
obviously if you wish to remove the rubber seal this will then totally disengage the front panel from the machine.
refitting is the reversal of dismantling.
i hope this helps others as I had nothing to work to as there was no information on the net of youtube.
if I've missed any parts out appologies as I'm doing this from memory.
Oct 20, 2014 | Miele W404 Washer
My Siemens HF759 (Stainless steel) front has come away from the glass and is only hanging via the top of the glass by the handle. How do I put it back?
You can remove the front glass and trim by removing the two torx screws at the top of the door, they are the ones next to the prongs that stickup from the door when open. Once these are removed the door front lifts up as the bottom is only hooked on. It looks like you need to remove more screws but you don't. A two person job as the door needs to be held in the nearly closed position as you lift off the front. Once you have the door off remove the two screws holding the handle on and it is then just the glue holding the trim on which in your case and mine has failed. I googled for oven door glue and found a very good site which has excellent instructions and video for application. The biggest hassle was cleaning off the old glue (scraper and acetone) and making sure it was aligned correctly before gluing, I used masking tape for a few dry runs as you only get one chance with the glue and it goes off quickly. Hope this helps.
Oct 08, 2013 | Siemens HF87950GB Convection Microwave...
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
How do I get the door apart to tighten the handle?
There is typically a plastic insert on the perimeter of the inside of the door that hides the screw heads. The screws may be TORX or TORX security (with the pin in the center).
Good luck with your project.
Thanks for using FixYa.com
Jan 29, 2011 | Frigidaire Microwave Microwave Oven
I just got a ntc Temperature Sensor for a W1213 Washer and was wondering how easy it is to change??
Easy.
Make sure there's no water in the drum.
Important! Switch off and remove plug from electricity supply!
Remove front base plinth (pulls off use a plastic lever if necessary - one inside soap dispenser drawer). Remove front panel of machine (torx screws at bottom, torx screw under drum. Slacken wire around door seal and remove (hook it with a smallish screwdriver. Do not damage seal. they are ridiculously expensive).
Unclip seal from front panel. Pull front panel out from the bottom, then down. Reach around the now detached front panel and unclip door lock wiring). Put panel somewhere it won't fall over.
Locate element underneath drum at the front - oval rubber with connections to it.
Temperature sensor is in the middle of the element. Unclip the plug from the back of the sensor. Gently but firmly pull the sensor out toward you. It's just a friction fit in the rubber. you can use narrow pliers but don't crush the socket of the sensor. If you want to test it, put a multimeter set to ohms on it. Resistance will vary under say a hot or cold tap/faucet.
New temperature sensor will push fit into old hole - moisten case first to make it easier with a tiny bit of washing up liquid (or spit!). You might want to test it first as above.
Reconnect wires, lock harness, front panel, attach door seal, attach door seal retaining wire, screws, base plinth.
Congratulate yourself on saving shed loads of cash.
May 21, 2010 | Miele Touchtronic W1213 Front Load Washer
How do i replace the door handle on a rca lvm135k 003
You will have to remove and disassemble the door. Look for a rubber or plastic cover that will be hiding the screws. The screws MAY be Torx or "star" requiring a special Torx tool. Torx available where ever fine tools are sold. It might also be #2 Phillips.
Don't try to use an allen key if it is a Torx, you will ruine your key and the head of the screw.
Once you get the door apart, it will be self evident what you must do to replace the handle. Get parts from FixYa.com advertiser, your local appliance parts store or order from www.repairclinic.com
Thanks for your interest in FixYa.com
Feb 16, 2010 | Microwave Ovens
I need to replace the seal around the glass in the lower oven door - what type of screwdriver is required to remove the screws?
Usually just a phillips head will work. Only other screws may be torx screwdriver but it is usually a phillips head.
Feb 01, 2010 | Neff U1721 Double circotherm Electric Oven
How do I remove outer door hinge housing to replace with new one?
there are four screws holding the hinge on to the machine. two are visible in the hinge from the front but there are two inside the machine on the left side .turn off the power and water supplies drag the machine out from its place tilt machine back to allow a gap between the drum and cabinet then using a star shaped driver also called a Torx driver remove the two screw from the hinge and remove it.when refitting a magnetic driver is a great help to prevent dropping the screws into the machine a torch is advisable to see what you are doing I hope this helps
Sep 19, 2009 | Dyson Memory CRO1 Front Load Washer
Oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Mar 13, 2009 | Maytag MER5555Q Electric Kitchen Range
NEED TO REPLACE BELT ON MODEL lde 412 series 02 serial no. 618 889 PX
its a maytag,
LDE 412 series 02, the labelling printing machine at Maytag is notoriously crappy
Unplug dryer
Remove two screws at bottom edge of front panel, under the lip facing up so they are hard to see.
  • May be TORX secure screws(star shap with a pin in the middle), TORX secure bits ~$6 at good tool shops, or cut a slot across the head of the screw and use a flat blade, throw the torx away and replace with phillips head screws, easier for next time
tilt front panel up from the bottom and unhook it from the catches
undo door switch cables
place door aside
lift drum out
motor, belt, bearings, felts, are all easily accessible.
check felts and roller bearings before you put the case back on, often a seized bearing is cause of belts breaking
While you have the case off pull all the lint n **** out of vent and motor area
Aug 25, 2008 | Dryers
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
