Question about GE 30 in. JGP336 Gas Cooktop
We woke up this morning and our JGP 336 is sparking on its own on all the burners randomly.It didnt get wet??
  • GE Master
  • 3,361 Answers
You have a stuck ignitor switch on one of your burner valve stems.
Remove the front panel. Remove one wire at a time from each switch. When the clicking stops that will be the bad switch.
Posted on Jun 17, 2009
GE cooktop ignitor jgp
Look for a short in the wiring (usually white wires running to the ignitors) or a loose ground wire. (usually green)
Jul 02, 2012 | GE Cooktops
Burner will not ignite but electroic spark s are working, sparks will not stop after burner is manualy lit
I have had this same issue with continuous sparking after a burner was lit.
Problem 1. Wet or dirty ignitors/burners. Solution: clean and/or dry (I assume this resolves electrical issues). This has usually solved the problem
Problem 2. Stuck or dirty control switch. Solution: remove knobs and spray electrical-cleaner into switches. AMAZING... no more clicking plus burners now burn hotter when set to HI. I assume this frees-up the movement of the switch to prevent it thinking you are pushing it ON... and thus asking for spark... plus greater range of switch and/or higher flame settings available once lit. A no-cost miracle! ( I used "PureTronics" brand Electrical Contact Cleaner spray can, 1 sec, 2X).
Mike S
Sep 15, 2011 | Viking 37 in. VGSU161 Gas Cooktop
GE JGP 945 continues to spark. Removed all igniters but continues to click. Bad Spark Module?
no,its a bad switch on one of the gas valves,they are piggybacked on the gas valve and are supposed to turn on and off as the valve is turned on and off,on has broken and is on all the time even with that valve in the off position,carefully remove each switch from the circuit till it no longer sparks with all the valves in the off position
Mar 30, 2011 | GE Profile JGP636 Gas Cooktop
My left front range has a spark and i didnt even turn it on it just did it by it self
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 30, 2010 | Magic Chef 30 in. 8241RT Gas Cooktop
How do I remove the spark igniter when replacing a burner bowl on GE JGP 636 gas cooktop
The spark ignitor is attached to the burner bowl by a retaining clip under the bowl. Simply remove the two screws on the top of the bowl, then you can slide the clip off from the underside
Jan 23, 2010 | GE 30 in. JGP326 Gas Cooktop
One burner igniter fails to spark after getting wet
Each burner has its own switch to direct current to the igniter. It appears that one of the four switches burned or shorted out, while the other three survived the flood. These switches are replaceable, so that's how I'll fix the problem.
Jun 26, 2009 | KitchenAid Cooktops
Ignition of burners is difficult and uncertain.
remove the burner caps, or heads and check all of the ports to be sure they are not clogged. Also be sure that when you put them back that they go into the correct positions.
Apr 09, 2009 | Cooktops
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Oct 22, 2008 | Cooktops
Clicking on one of the burners
sound like the spark switch got wet or has failed, if it has gotten wet from cleaned to stop the clicking unplug the ct of 24 to 48 hrs to allow time to dry out if that does not work call a appliance service company
Jun 03, 2008 | Jenn-Air 35 in. JGC9536 Gas Cooktop
GE 30 in. JGP336 Gas Cooktop Logo
266 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
