Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
MOWER DOES NOT SEND CLIPPINGS TO REAR BAGGER
OLDER MODEL JOHN DEERE RIDING LAWN TRACTOR
can any one tell me how to repair?
Cutting grass but it isn't going into the bagger?
grass catchers need special shaped or good blades to throw the cut grass into the bag
check/ replace the blades
May 06, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
Do I need to switch to the high lift blades for my rear bagger to work right?
Yes. I use gator mulching blades during the summer. They won't bag a thing. The original/standard blades will bag some grass/leaves, if they are dry and not too dense, but they are prone to clogging. The high lifts work much much better.
I get mine on amazon. The shipping is free. LA145 48" deck. Part GX21785.
http://www.amazon.com/gp/product/B00CAXMAG2/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1#product-description-iframe
Apr 13, 2015 | John Deere Garden
Where would we get as manual for the d170 john deere grass bagger
Try this link to Deere customer support:
http://manuals.deere.com/cceomview/OMM167392_B2/Output/Index.html?tM=HO
If that's not your model, look around - they do seem to have quite a few manuals online, and offer to sell you a paper copy if they don't have an online version. Good luck!
Aug 08, 2014 | John Deere Riding Lawn Mower. D170 54 in....
Is there any manual for a john deere riding lawn mower model # la115
if you look up "john derre riding mower" blog or club, I'm pretty sure you will eventuality find a bunch of lawn mower enthusiast, with alot of time and resources on their hands. Most of the time you can find rare parts, paint, manuals and lots of extras.
Jul 16, 2014 | John Deere Garden
How to attach a john deere grass catcher
Make and model are important and would help. Generally they are pretty simple. Some older models you had to bolt a mounting bracket to the rear corner of the frame and then a support slipped into the bracket. Some newer models have a drop in feature (these have rounded ridges on the back of the frame and have horizontal slots cut in them). On these the support bar simply drops into the horizontal slots then a swinging bar slips into 2 holes on the fenders to support the rearward hanging weight. The most important part is getting the right bagger model for your model. If it is a very old model that discharges grass out the back of the deck you may have a hard time finding a bagger at all. If you have a side discharge just make sure you are getting the right version for your tractor. If your tractor has a smooth flat back you need the version that has a bolt on mounting bracket. If it has the rounded vertical humps you need the newer version.
Oct 01, 2012 | Garden
Bagger won't pick up green grass
There could be a couple of reasons for a bagger not picking up clippings. One could be a clog in the ducting or in the air venting from the catcher (if applicable). Second could be worn out blades that can not generate the power to move the clippings to the catcher.
If this is really helpful, please rate.
Jul 10, 2011 | John Deere Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Chute for bagger keeps getting clogged
John Deere LA 125. Chute keeps clogging up with grass.
Apr 22, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
52 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
