Question about Asrock K7S8X-R3 Motherboard
Ide port not picking up
I have tried everything and nothing work can't find the hard disc and the dvd burner and its a dell board
    President:
  • 828 Answers
Are you using IDE or sata configuration, tell me..
Posted on Jun 17, 2009
Cd/dvd drive not recognizing discs
You will probably need the ide file. It sometimes gets corrupted. I used the Atapi ide file and it worked on a Toshiba drive. It can be found by doing a search and can be downloaded as a seperate file.
Feb 09, 2010 | Dell Computers & Internet
I want to install a 2nd dvd burner. But I don't know how to hook it up. My new pc does not have the ribbons like my old one does.
If your 2nd DVD burner is on IDE interface, you may need to get an IDE to SATA cable. Please refer to the picture below as to how it looks like:
Oct 29, 2009 | Compaq Presario 5000 PC Desktop
Trying to burn photos from dell laptop to DVD-RW blank disc . "error - no disk in drive"
Try another disc first ,if no luck than try another disc manufacturer. If it does not help check if you can play anything from this drive if no, check drive connection in your laptop you can also can check BIOS settings for this DVDRW drive and settings for IDE or Sata data transfer mode make shure it works in Ultra DMA not PIO mode. Be carefull with BIOS Setup!!! If nothing helps replace drive. Good Luck!
Jun 24, 2009 | Dell (7W036) DVD+RW Burner
Dell E510 Missing CD & DVD Drives...nothing is working yet...
you can buy that type of hardware anywhere since it is standard for all desktop. Your current drive is IDE meaning that the data cable on it is an IDE type.
Go to your local computer store and ask for a DVD writer IDE, since there is really no price difference now for a combo or dvd writer drive, it will be like 10 $ more for the writer. I live in canada so if you are in the US could be less here a DVD writer is around 35 $ at a computer shop.
Here is the spec of your computer just in case :
Dimension E510
May 28, 2009 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
How do i install a second writable disk drive???
aloha...this can be done, IF your computer has the expansion capacity. what kind of computer are you using?
Mar 17, 2008 | AOpen : CDRW 52x32x52 Beige Color Retail...
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My MD16XDVD9 doesnt work. Its power is on with the small greeen light flickering and the bigger green light steadily on. but the the DVD tray doesnot open automatically. Even if it is force-opened and a...
have you got it set on an IDE cable on it's own and if so have the jumper at the back set to master the other thing to do is power of pc and remove ide cable from all devices and leave power cable to burner then torn on pc if you have removed power and ide cable from hard drive then when pc boots in press button on cd,dvd drive to open tray then place cd lense disk or any cd in drive tray press close button and let device kick in if it picks up disk then try with a dvd disk with power on pc if all goes well try with a ifferent Ide cable to motherboard and reconnect harddrive and power up if all goes well the pc should recagonise it if not then get it replaced
Aug 06, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Dvr-106d -Windows freezes,cant read new Dvds
if you have had two drives with the same problem i would check the ide cable and swap to another one if you have a master and slave twin connector ide cable, or even try the dvd rom on the same ide cable as the hard drive as you know that that ide connector and cable is working, unless you have a SATA hard drive in which case you won't be able to; but will still have a spare ide channel connector to try the drive on.
Jun 26, 2007 | Pioneer (DVR-106D) DVD±RW Burner
Asrock K7S8X-R3 Motherboard Logo
55 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
