I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
If I understand you correctly, you're saying that the LCD display shows a normal picture when you are composing your shot, but that when you actually snap the shutter to record the shot, the resulting image has nasty lines across it?
That would indicate that the lens is fine, but that the image sensor itself or associated electronics have gone bad. If this is out of warranty, then you're likely out of luck.
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol).Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Actually, try manually turning off the flash and taking a picture. If the shutter works and takes a picture, then suspect that your flash is burned out. Unfortunately it's not a simple task to change a burned out flash tube.
