Question about Toshiba Satellite A135-S2386 Notebook
Fingerprint scanner- can't access settings
Same error as below- did anyone get a fix for this?
    President:
  • 828 Answers
Install properly the program of fingerprint scanner...
Posted on Jun 17, 2009
Biometric fingerprint scanner acer
That is because it has not been removed from User Accounts.
Dec 29, 2013 | Acer TravelMate 8371 Timeline (LXTTD03077)...
Will anyone have access to my fingerprint info if I choose to use the fingerprint scanner on the iPhone 5s?
According to Apple, your fingerprints will not be stored in the cloud and will not be available to other apps.
Sep 11, 2013 | Apple iPhone 5S
Unable to obtain authentication input/output. unable to obtain authentication input/output error has occured. error while loading applet module is not registered
if u r using your scanner on jamb website. You will need a biometric license and offline software. We have several license in stock to give away. While not call us today, if the problem is still persisting. Call 08132829820
Dec 01, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
Unable to obtain authentication input/output error has occured. error while loading applet module is not registered
Nov 19, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
HAVEA TOSHIBA LAPTOP WITH A FINGERPRINT IDENTIFIER TO OPEN WINDOWS, WANT TO CHANGE THE FINGERPRINT TO MY DAUGHTERS. HOW DO WE ACCESS THIS?
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
  1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
  2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
  3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
  4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
  5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
  6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
  7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
  8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
  9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
Feb 03, 2010 | HP Pavilion DV5234US Notebook Laptop
I have H P Pavillion DZ6500 which I just upgraded to Windows 7 Professional. The Verisoft Access Manager that drives the fingerprint scanner is not compatible with Windows 7. Any suggestions?
Hi:
I fought the same thing with another fingerprint scanner, and even spent some quality time speaking with Micro Soft Technicians....It seems they are not really supportive of fingerprint scanners,And forget getting any support for Window 7, 64 Bit version. My fingerprint scanners were Microsoft brand, and still no 64 bit support...
Nov 24, 2009 | HP Pavilion tx1000z Notebook
Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Jul 16, 2009 | Canon Pixma MP480 All-In-One InkJet...
HP --Bioscrypt Verisoft fingerprint reader -- Error
somewhere the permissions for the login are not set correctly. If you have a windows disk back up the user settings remove the user and after the restart add the user again and that should do the trick
Dec 30, 2008 | HP Pavilion tx1000z Notebook
Finger Print Scanner
Hi again. Give me your email adress please, for me to send you the required upgrades. Read my other post in the other section you've wrotten and you will have the instructions on how to do everything there. Thanks.
Jan 22, 2007 | HP iPAQ H5450 Pocket PC
Toshiba Satellite A135-S2386 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
