Question about Asko T781 Electric Dryer
My dryer is making an increasingly noisy rolling sound when in use. It is an Asko T701 model
  • carol_giroua Jul 28, 2009
    Well I finally called service, and my problem was LINT! There's a door under the dryer to clean out, that isn't in the instruction manual for maintennance. Turns out on this model that the manufacturer has also developed a better, more air tight lint screen.
    Problem Solver:
  • 12 Answers
I had similar problem. Believe it or not - all I had to do, was adjust 1 'foot' under the dryer! I guess it wasn't sitting very level. I only wish I would have figured it out a looong time ago!
Posted on Jul 28, 2009
  • 121 Answers
Sounds like your drum guides or felt thats wore
out or something stuck inside there rubbing
Posted on Jun 18, 2009
What does the code C3 mean on my Asko Dryer
Asko electric dryer model T701 has timer-controlled drying in addition to the two automatic (thermostat-controlled) programs. Without electronic, there isn't possible display fault code.
Dado
Sep 26, 2014 | Asko T701 Electric Dryer
Asko dryers
Akso makes "condensing" dryers (Models T721 and T781) that condense the moisture wich then is directed to a drain. The T701 is a vented style dryer so I'm a little confused.
Dec 15, 2009 | Asko T701 Electric Dryer
Need to replace the belt on the asko t701 what is the difficulty level doyou have a diagram
NO DIFFICULTY- PUT THE BELT ON THE SMALL PULLY FIRST IN THE GROOVES AND ROLL THE LARGE PULLY AROUND A COUPLE OF TIMES TO POSITION THE BELT
Oct 04, 2009 | Asko T701 Electric Dryer
Asko t701 dryer makes exsessive noise and drum rotates slowly
Mine was very noisy. Then I found the impeller clogged with lint. I cleaned it and now the noise is gone.
Remove the lower panel (2 Torx T20 screws).
Remove the impeller cover (1 Torx T10 screw and 4 snaps).
Clean impeller.
Reinstall covers. Don't overtighten screws.
Sep 10, 2009 | Asko T701 Electric Dryer
My Asko dryer shut off and my clothes are still wet. It won't start and the light on the pannel will not come on. I know I probably have lint in the system that escaped the lint trap or maybe something...
YOUR DRYER Has a fuse in it look for it probably somewhere close to where the main power comes in at. if it's good check the heat relay contactor assembly. www.repairclinic.com has the model you have and it may even be as simple as the door switch
Apr 09, 2009 | Asko T701 Electric Dryer
VERY noisy GE profile electric dryer
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=DPSQ495ET4WW&mfgModelNum=&fkMfgID=2 The problem you are having is with the front glides and the back bearing . # 316 on the door diagram.& # 543 on the drum diagram. those are the parts to replace.
Dec 22, 2008 | Asko T701 Electric Dryer
CAN'T FIND INTERNAL FUSE TO REPLACE IT
I've never seen a fuse in an electric dryer, you could have another problem. List your symptoms and the voltage of the dryer.
Nov 25, 2008 | Asko T701 Electric Dryer
Asko T781 Electric Dryer Logo
276 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
