SOURCE: GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
SOURCE: good evening, under the cycle selection buttons on
The fact that it does work (briefly) on one of the cycles but not on any others, points pretty strongly toward the control board. It's a pretty expensive part, so before you buy it you need to open up the door panel, and make sure that it hasn't come loose from the pieces inside, which would prevent it from making contact with the buttons on the front.
Of course make sure that the breaker to the unit is off, or unplug it, if possible.
SOURCE: GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
SOURCE: The Normal wash cycle won't light up. Only china
does the normal wash cycle work though sometimes a ligt might be gone on the control if the wash cycle doesnt work then your in for some headahces unfortunatley you would have to be able to diagnos which is the problem either the main control or the touch pad it all depends on how old the unit is ive seen both of these go you can find the part online at marcone appliance parts if you have a problem diagnosing which it is please call a technician and they will be able to tell which one is malfunctioning
SOURCE: GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
