Question about Karcher 2500 PSI Pressure Washer
The presure pump is not working.
When you torn on the karcher presure washer it will not start,
    Sniper:
  • 79 Answers
Try to release the pressure from the wand. Take of the tip if you have to. If that doesn't work take the spark plug out and pull, oil may have gone into the valves. Clean the plug and put it back. It will clear, the smoke that is. Lemme know. Please rate me
Posted on Jun 18, 2009
Had presure tostart cleaning @ then press. stopped just seem to have water press. thank you
if the motor is still running fine when this happened it is either a failure in the linkage between the gas motor and the pump. or the pump itself. if it looks like the motor does nothing whatsoever. it may be the link between the two. if the motor does a little bit, then the problem may be with the pump. Try turning off the engine while spraying and see if the pressure drops at all
Aug 08, 2011 | Honda Karcher G2400HH-R Pressure Washer
It's a Karcher presure washer K2.54, one and a half years old. Was working fine last time but when turned on now there is very little pressure through the hose and the water seems to be filling up inside...
this sounds like the seals may have been damaged inside the pump or that the water inlet/outlet could be damaged. If you take off the front cover (use a star bit screw driver) then run the pressure washer you will be able to see were it is leaking from and then you can get the right part to replace it.
Mar 16, 2011 | Karcher Garden
Very low pesure
Make sure that all the air inside the hose is out, sometimes pressure washers have a hard time bleeding out the air. Lastly it could also be your pressure relief inside the valve body of the pump the spring can get bound up and basically stay on relief, like when you let off the trigger it doesnt just blow the line or stall the motor good luck\
Apr 18, 2010 | Karcher 2500 PSI Pressure Washer
No peessure
if you have good water flow to it and you have water coming out of the lance when you pull the trigger but its not under presure then it will most likely be bad valves in the pump head or worst case a fault in the pump. any questions just ask away
Feb 20, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Aug 17, 2009 | Karcher 2500 PSI Pressure Washer
When pressure washer handle is activated I get a burst of water then the pressure goes away
The machine has a worn by pass valve. Change valve assembly. Also check high pressure valves are not worn or blocked,
Aug 07, 2008 | Karcher 2500 PSI Pressure Washer
I own a karcher water blaster 449M and needs an expert to solve the pomblem It does not bring out the presure required to the right job and makes a noise as well when you start it can someone please let...
sounds as if you have a pump problem. your best bet is to go online to maker or a dealer near you for service help.you may wind up having to replace pump.
Jun 20, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
269 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
