My pc (windows XP) wont boot
I just had my drive c reformatted. it worked fine and so i left it for awhile. but when i came back the monitor just showed a black background with all these letters and numbers. i restarted it but still the same result. it won't start no matter how many times i reboot it. need help here guys! tnx!
  • Sebastian Spudik May 11, 2010
    you formated drive c and now there are letters and numbers flashing through the screen?
    When you reboot, have you some kind of startup cd or dvd (windows installation, Windows PE and so on) in your optical drive?
    Or have you installed your operating system on another drive?
  • 73 Answers
Insert the windows xp disk in cd bay...boot the computer with the cd...and try the fresh installation of windows xp
Posted on Jun 17, 2009
Computer boots only after several attempts to read hard drive. The hard drive works fine and there is no disk access problem if machine is left on continuously. The machine may power off and on numerous...
If you may have de-fragged the hard drive recently and compressed the executable file for Windows. You can load into your windows back up ur file and reformat with a fresh load of the OS. You can as well try a Windows repair using your restore disk.
Aug 16, 2010 | HP Pavilion dv6000z Notebook
How to reformat a computer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 19, 2010 | Microsoft Windows XP Professional
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
How to reformat back to windows vista ?
You need a windows Vista disc. Insert the disc and follow the prompts. I would format the hard drive instead of upgrading do a new install. The best way would be to go into your bios and make sure the boot device order has the cd-rom booting before the hard drive. Then put the disc in and start the computer, when it says press any key to boot from cd hit any key and let it load and then follow the prompts to install.
Nov 27, 2009 | NEC Versa VX Notebook
I recently reformatted my computer with windows xp and after everything was done I rebooted my computer but it always gets stuck on the HP screen where I can press ESC to go to boot menu and F8 for...
I am assuming you have already backed up all of your data before doing this. But, it probably hit a bad sector on the drive. To get around this just insert the CD again and boot from the CD. When prompted on the screen, you will want to delete your partitions and do one large partition. That should help.
Oct 26, 2009 | Microsoft Windows XP Home Edition
No windows xp
You will have to reformat it again. its likely a bad sector has been created on the hard disk, and windows file is probably occupying the bad sector. Try to reformat your hard drive. If that doesn't work, try to reformat it with windows 98 bootable disk. If it doesn't work, get another hard drive and test to see if it will work. If that works, then know you may have lost the MBR (Master boot Record) of your hard drive.
Apr 14, 2009 | ASUS A6J Notebook
My computer wont boot up. I try to send it to safe mode but all I get is start-up repair and then it tells me it can't fix the problem. Any Ideas?
you need to repair you OS. You can do it by booting up with your Windows CD.
then "set up windows xp"
press F8
then at the drive selection " where your windows xp is installed" Press "R"
don't worry it won't reformat your drive, its going to repair the damage it has.
Mar 09, 2009 | Acer Aspire (AST180-US340B) PC Desktop
Installation of windows xp on vista
Reformat the hard drive first using. Take VISTA off.
Jan 10, 2009 | Microsoft Windows XP Professional With...
Desktop doesnt boot.
If you have a windows XP recovery CD, try running that at boot.
also, try pressing the f8 key to boot windows in safe mode.
it sounds like a corrupted OS install: if you can't recover, you may have to reformat your hard drive and reinstall windows.
Mar 29, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
42 people viewed this question
Alun Cox
David Payne
David Payne
