Question about Toshiba Satellite A105 Notebook
Toshiba satellite A105,My wife dropped laptop now when you try to start I get error message operating system not found, try to boot to bios and get several quick beeps
  • 31 Answers
it sounds like the hard disc crashed on some sector, on which important files where located.
Insert your Windows Installation CD/DVD and try to repair your installation.
Posted on Jun 17, 2009
  • 43 Answers
Harddrive has probably crashed or the connection have become loose. Flip the laptop over and look for the Harddrive assembly. Usually has 1 screw holding it in place. If you feel comfortable enough - remove the screw and pull the HD out and slide it back into place. See if the connections are simply loose.. If that does not work you probably need to replace the HD.
Okey i have a toshiba satellite a105 s2071. it was given to me but the person doesnt have the recovery disk and i tried so many ways to factory recover my notebook and nothing works what can i do????
hello. can you explain exactly what is happening.
Does the bios boot up? Does the operating system start assuming windows xp? Are you looking to recover previous work or a fresh install?
Jun 16, 2011 | Toshiba Sattelite A105-S2071 Notebook
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
My toshiba a105-s4034 will start to power up and the hard drive light stays on a few seconds then goes out the display does not come on.if you do not put any memory card in bay close to hard drive computer...
Your computer is trying to boot up when your memory card is installed. The memory card doesn't have an operating system therefore the computer cannot boot . You can disable all of your bios. options except for the hard drive in your bios settings which you access right after you start the computer . You'll find it by using the arrow keys and selecting boat device options in the bios settings .
May 13, 2010 | Toshiba Satellite A105-S4034 Notebook
Will not boot says operating system not found
if it was working before that message, then probably the operating system is corrupted.
insert the windows cd when you boot your pc and when the message "Press any key to boot from dvd" appear press enter.
Follow the screens to repair Windows. the sytem files will be restored.
Jan 25, 2010 | Toshiba Satellite A105 Notebook
Toshiba satellite A105 operating system not found, wife dropped laptop
usually a harddrive is designed to withold a drop (to some extent), so one of 2 things happen. either the head of the hard drive touched the drive (internally), and killed the hard drive, or the hard drive simply got loose where it connect. i would unscrew where the harddrive goes (easy don't panic about it, 1 or 2 scres tops) and take the hard drive out then put it back in. if the harddrive is ok, u should be back in business.
Jun 17, 2009 | Toshiba Satellite A105 Notebook
I would like to reset my computer to the day I bought it.
OK, you need to locate to system CDs that came with your laptop. One of them will be disc 1 or operating system or Windows CD. Insert into the CD ROM drive. Power up laptop and when "Press any key to boot CD.." is displayed, press any key on the keyboard. If this message doesn't display, then the CD will boot and just follow the on-screen messages to install your OS. If your laptop doesn't boot the CD, then you need to go into your BIOS and set the CD-ROM drive as the 1st boot device. Follow on-screen messages during boot-up to enter your BIOS or try pressing the DEL or F1 or F2 or F12 key while powering up your computer. If you do not have the system CDs, then you need to call Toshiba and order them.
Apr 25, 2009 | Toshiba Satellite A105-S4254 Notebook
My Toshiba satlelite A105 will not boot up , comes up on screen black says pxe-e61: media test failure, check cable pxe-mof: exiting intel boot agent operating system not found
Go into SETUP (F2, DEL, Cntl-S or somesuch at boot time - or hold F1 key down and force and error and then change your BOOT order to CDROM, HDD. It is Currently NETWORK, CDROM, HDD or the like.
PXE is Network directed bootup, and your LAN connection is waiting or the proper code or instruction or server. You need to turn that off, and BIOS SETUP is where to do it ;-)
Hope that helps
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A50
When the system boots hit the BIOS key F2 and in the setup select boot from CDROM and press F10 and exit, Insert the bootable CD and boot the system
Jan 06, 2009 | Toshiba Sattelite A105-S2071 Notebook
Toshibs sat. A105 won't let me boot to any cd it says operating system not found
you need to enter your bios (setup at boot) and make sure that the cd drive is at the top of the boot sequence before it can start from cd.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
