Question about Canon Pixma MP500 All-In-One InkJet Printer
Wont print red
I replaced all my ink and now my printer will not print red at all!
You may need to do a few nozzle checks/cleanings. You also need to be sure you removed the seal strip from that cartridge...otherwise it can't breathe and won't dispense ink.
If the problem was that it wasn't printing red before you changed the ink and the problem persists, it could be a clogged printhead that may or may not be salvageable. Try the machine's cleaning function (not deep cleaning right away...try a few standard cleanings, printing off test pages in between to see if you are getting any improvement.
Posted on Jun 17, 2009
Wont print. solid red ink light. wont display ink levels
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Nov 18, 2011 | Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Hp 6500A Wont print red... Have googled around...Can't seem to find solution ...
The ink head needs to be cleaned, use a cotton bud and surgical alcohol. Also try using the head cleaner via the software provided with the printer. This problem usually occurs after installing a replacement ink cartridge. The ink basically gets dry and hard around the nozzle and therefore prevents the ink from flowing through and onto the paper. Print red a bit it may come through if you printer a few red demanding pages. Use Microsoft paint.
Take care!
damnor01
May 29, 2011 | HP Officejet 6500 Wireless All-in-One...
The printer says i need to put in color ink cartridge.it is in and wont do anything
if the red light is still flashing then try and reseat both the ink cartridges and print head and make sure you use genuine kodak ink cartridges as there are retailers selling look alike and refilled ink cartridges.......if still the same problem then print head problem call kodak tech support they will replace it for you without any charge........
Jul 07, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My Stylus C66 won't work.
You have to replace all ink cartridges, it is somekind selling trick. I have epson printer too and it wont work if you replace just one ink, and i have 6 ink cartridges :D
Jul 06, 2009 | Epson CX8400 All-In-One InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
R220 epson printer not printing
ensure u r using original ink cartiges try head cleaning process replace all the ink cartriges
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Our kodak 5100 printer wont print red
just open home center and click on the question mark on the top right and click on maintenance in the right and click on clean print head.............if you still get the same issue then just take both the ink cartridges out and on their side there is a number and just reply me back with that number and i will let you know if its genuine ink cartridge or not.........coz there are lot of look alike and refilled ink cartridges in the market which you wont be able to make out............
Jan 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5100 won't print
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Sep 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My troublesome printer
New ink comes with a strip attached at the ink hole and sensor area, makes sure u ermaove them also try to clean the catridge contacts in the printer
Mar 06, 2008 | Epson Stylus C60 InkJet Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
old marine
old marine
