Question about Bosch & Tankless LP Hot Water Heater
Unit fires up, runs 10-20 seconds then exaust motor makes clankings sound and shuts down. Error code flashes E1 for a few seconds then unit fires back up, repeating cycle. Seems to be plenty of water flow through unit.
    President:
  • 3,433 Answers
Chances of a critter in the fan? Like a dead 4 legged critter?
Posted on Jun 18, 2009
What does a C4/76 error code mean
I just went through lots of troubleshooting the same problem. Most searches will tell you its a communication error with the remote. After I was able to rule out the wiring, I bought a new remote ($70), hooked it up and immediately got the same error. Called Rheem Tech Support at 866-720-2076. They said code 76 meant I needed a new control board and chip. My unit was out of warranty but they sent the needed parts and detailed install instructions the same day, via FedEx overnight! It was a very simple task to replace. I happen to own 4 different units and am very glad I chose Rheem brand. Its not often I encounter a company willing to stand behind their products, even after the warranty period. Oh, and if you disconnect the remote control wires from the main unit (unplug unit, then remove face panel and they will be labeled, hooked on 2 small phillips head screws, replace panel and plug back in) your unit should still (more often than not) kick on and heat to about 100F by default...a do-able shower temp :) hope this helps!
Sep 28, 2014 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
Takagi t-k3 runs hot on low to med flow on high turns cold & flame shuts off
OMG 95 PSI is too high a pressure for a tankless! What was the W.C. in inches on the manometer?
Also on a T-K3 12 isn't a Code but a partial Code. You need an R/C to make this easier as counting led flashes produces wrong codes.
you'll have to find the correct code it's throwing not a partial.
And put a Pressure Reducer on this to below 60 PSI. 95 PSI is only impressive when it blows the tubing out after a few years.
Call Takagi in California not A.O. Smith in TN and they'll help someone fix this
Sep 20, 2014 | RTO Takagi T-K3 Flash Gas Tankless Water...
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
Paloma (Rheem) tankless water heater 7.4 gpm 199,000 btu outdoor unit. Red light is blinking on pc board. unit fires up for approx 2 seconds then shuts off, then cycles once more for 2 seconds and shuts...
i think your flame sensor is bad but you will need to confirm that with rheem i am unsure what the c7 is for but code 12 is flame failure and there could be carbon build up on the flame rod...
Aug 06, 2010 | Rheem Tankless Hot Water Heater...
PTG-74PVN Error Code -0 14 and LED on the controller board flashes 4 blinks every 6 seconds. Fan turns on few seconds after power up then stops. No fan, no spark, and no fire when water flows. Where can I...
code 14 is a big deal shut that thing down! you will burn it up if you keep running it, your over heat wrap on the heat exchanger is too hot. call rheem they can walk you through it
Aug 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
C4 76
76 is a bad connection between the controller and the unit. try unplugging the controller and running it, also check the wiring between the two units. if that is not it. it means that one of the control boards it shot
Jul 18, 2009 | Water Heaters
How to correct error code C-7 on my RTG-74PVN Rheem Pronto
I had the same problem and called the manufacturer. The error code C-8 was followed by the number 76. They told me to disconnect the thermostat/digital display from the main unit. This was fairly simple to do by removing the front panel. The unit works steady now without shutting down after a few minutes. The help desk told me that the main circuit board needs to be replaced for the unit to work with the display and that they would mail me one asap. At least we have hot water again.
Oakville, Ontario
Jan 11, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Dec 31, 2008 | Rinnai Webstone The isolator EXP tankless...
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Bosch & Tankless LP Hot Water Heater  Logo
220 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
