Question about Ricoh Office Equipment & Supplies
Ricoh afcio 1045
I have a problem in my copier aficio 1045 same as 1035 the prorlem is sc 542, i already replace the termo fuse but is not work it then i replace the termistor 1 and 2 but after 5 hour the code are came back
I have had several of these models give fuser codes that were on shared circuits, without surge supressors installed. I would suggest either trying another outlet (preferably dedicated), and/or installing a supressor.
The other thing to check is the the condition of the plug connector on the back of the fuser and on the machine that contacts are in good shape, and clean.
Posted on Jun 18, 2009
Error code sc200 on a ricoh afcio mp c1500
Turn Machine off then on.
If it doesnt work press on keypad [*107 Clear] then press System SP. then turn Off the On.
Mar 29, 2014 | Ricoh Aficio 1035 Copier
Err cod 542 Ricoh 1035
replace the thermostat & reset 107 turn off & on the the main switch. sometimes the body of the fusing unit that hold upper roller bushing get damage. if u reset it will be ok, and at certain time the code will appear again. if the body of fusing unit got broken then u got to replace it. once more, check the thermostat, normally 1 of them got broken.
Aug 25, 2011 | Ricoh Aficio 1035 Copier
May ricoh 1045 bao loi SC 329,mong cac chuyen gia giup do
this is laser unit code.press reset 107 hold the c key. press copy sp go in drum perform2109 400dpi initial setting and 600 dpi initial setting.
Aug 07, 2011 | Ricoh Aficio 1035 Copier
Ricoh aficio 1045 - SC541
Fusing thermostat/thermistor open
Symptom: The fusing temperature detected by the
thermistor is below 10°C for 5 seconds
after the main power switch is turned
on.
Possible Cause:
• Fusing thermostat defective or out of
position
• Fusing thermistor defective or out of
position
• Power supply board defective
May 25, 2011 | Ricoh Aficio 1035 Copier
Problem with the Ricoh mp c2800 Ricoh error code sc 672,
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Nov 15, 2010 | Ricoh Aficio 1035 Copier
Hi.... sc 395 with aficio 1045 , what is that mean & how can I fix it.
If it's 395 that's a development bias error, check and reset the developer. Power off/on to clear both.
Jan 30, 2010 | Ricoh Aficio 1035 Copier
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 from Networked Unit to Stand Alone
There is a service code to disable the key counter. I'll have to look it up. If you are not connected to a network, you can still use the copier without being hooked up to one. That is just a warning message. You can clear it out by pressing user tools counter. Select interface and set all ip addresses to 0.0.0.0.
Jan 29, 2009 | Ricoh Aficio 1035 Copier
91 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
