Question about Samsung HLR5067WX 50" Rear Projection HDTV
I have a samsung rear projection tv and has ghosting on picture? what could be wrong and is it easy to repair?
  • Samsung Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneeri have a samsung rear projection tv and has - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Ghost images . all 3 colours auto convergence doesnt help
rear projection tvs are not easily repairable  there is no solution but an expensive replacement of all 3 picture tubes    it is basically a disposable tv   time for a new one
Nov 03, 2009 | Zenith R56W36 56" Rear Projection...
Red and green ghost image
needs conv.ics need tech help.most tv repairs
need a technician.this web site is a joke.
Jul 19, 2009 | Samsung HC-P4752W 47" Rear Projection...
The red is forming a doube image on the picture
You mean red ghosting
easy , replace both cnvergance chip
if you have a repair shop fix it don't pay
more then 175.00 . It's an 1 hour job
and the part cost about 30.00
Jun 30, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Green ghosts
these tv are night mares best case get rid of the projection tv period go with a lcd flat pannel and make sure it dsnt have a lamp
Dec 30, 2007 | Samsung HCN4727W 47" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
