Question about Venturer STS-35S System
Speakers with TV...
I have the cable box audio output going into my Home Theater system...but it only plays the 2 front speakers. Is there anyway to get it to come out all the speakers or will that ONLY work with DVDs...
Program to satellite
Posted on Aug 02, 2008
Install home theater insignia
How are you connecting the devices?
If you have used the cable box audio out (RCA) to the audio in (the ones just right of the digital coax audio out and the S-video out) on the home theater system, make sure that you have selected the correct Source. (Use the Source button on the front of the system to select AV1 or AV2. This toggles between AV1, AV2, tuner and DVD. It's the right-most button below the display screen. Alternatively, use the Tuner/Aux button (second from the bottom on the left) on the remote.) Note with this connection, the video source cable should go to the TV directly. Unless it is a composite video signal. Then connect the RCA video out (REC out). Make sure that the audio digital output is off. Press Setup/Exit (just above and to the right of the arrow keys) on the remote. Go to the audio menu (press the left arrow key twice) and press OK. The first item in the list is the digital output and should be blank unless you are feeding the audio to another system.
Next try a different audio cable and check that your speaker wires are all connected. Check that the cable box is getting power and a signal from the provider. Connect it to the TV to recheck. If it isn't, make sure that the cables didn't come loose on the box while you were making the connections to add the system.
If you have a newer cable box with HDMI or digital audio out, these most be connected differently. A digital to analog audio converter will work with the second option. For an HDMI connection, connect that cable to the TV, then connect the TVs analog audio out to the NS-H2002. Then go to the Audio menu of the TV and turn on the external audio and turn off the internal speakers. (If your TV has a headphone jack as the only analog out, then this step may not be needed. However, you'll need a 3.5 mm to RCA stereo cable or adapter.)
Check if the audio works with another source (like a DVD). If another external source works, then it's the cable box or the connections to it. If no external sources work but you can here a DVD play, it's probably the input jacks on the system.
I hope this helps. Please add a comment with more information about the cable box outputs and the TVs inputs and outputs if you need additional assistance.
May 22, 2012 | Insignia NS-H2002 Theater System
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
I don't know how to hook up my LG lht854 to my time warner cable box so that it plays the tv audio. please help
Treat the Cable Box like any other audio device.
IF the cable Box has optical digital output, run it to the LG. Run the analog audio output of the Cable Box to the TV so you can watch lo-fi shows without the LG turned on.
The best Cable Box Video should go directly to the TV.
Register and download the manual for free at
Mar 19, 2011 | LG LHT854 Theater System
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
I have a panasonic viera flat panel plasma tv and a samsung 5.1 ch blue ray home theater system and the speakers work fine on the home theater system while playing a dvd, but does not work when watching...
1. The easiest solution would be to connect a stereo RCA (red and white) cable to the audio output on the back of your TV.
2. Then connect the other end to the input on your home theater system.
3. Change the home theater system to the correct input.
Feb 12, 2011 | Samsung HTC550 Theater System
I have the bd230 5.1 system hooked up the speakers, attached the power cord and hdmi cable from receiver to the tv what else do I need to get sound from my tv I have a hd do I need to run a cable...
The home theater box performs the production of the sound generation. Also, the theater box, distributes the sound to any display devices like TVs, Music MIxers, DVDR, VCRs, ext. The theater box also has connection ports that are recognisable as receptacle area from speakers, woofers, and twitters that combined to form the home theater of devices acquired. First, start by connecting the component parts of the theater system to the box. For example, speakers to an area on the box, twitters, woofers. At which point, the box would require a power cable to an electrican circuit to display functionality mode. The next step is deciding on which display reciver would be providing sound to the theater setup of blasters. For example, choosing to acquire sound from a TV set is achieved by connection cables that derived sound out of the TV to the theater box. E.G. The TV audio output area provides the connectivity of any external audio blasters like with the theater setup. Using the appropiate audio input output connection cables to acquire sound transfer matters. The device may not have been provided with a TV audio input out cable of connections. Acquire from retail input output cables from TV to theater boxes. Remember that, the theater box may have come with a remote control that require separe operations than the TV. The theater system theraafter would require power on buttons if any separate remote controls were acquired as well. Also, the television set would require alteration settings with the remote control. Adjusting the TV sound settings to acquire or direct internal sound to an external setup infrusture is possible explanation also achievable with TV REMOte controller soon after every wireing cables have been established alos powered on to source of current. GOOdluck
Jan 11, 2011 | Panasonic Home Theater System System
I cant get the lg lhb977 to work with my cable box. what do i need to set up to hear regular tv not just blue ray and dvds
All i did was run regular red and white audio cords rom my cable boxs audio output to the lg lhb977's regular red and white audio input. and press function enough times on the front of the system till it gets to "AUX" and then it worked for me. As long as you go to ur actual tv options screen and try to set ur speakers to "external speakers" rather than "tv speakers". hope it works
Oct 13, 2009 | LG LHB977 Theater System
Need owner manual for 8-watt Durabrand Home Theater System or directions on how to hook it up to flat-screen tv with built-in dvd player or digital dvr cable box
I would appreciate if you could let me know the manufacturer name of Duraband Home Theater system.. I'll paste the link to download user manual.
Awaiting response.
Thanks !
Sep 08, 2009 | Durabrand 5.1 Surround Sound Computer...
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Venturer STS-35S System Logo
118 people viewed this question
Top Venturer Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
